Piggy Back Electrical Site Hook up Cable????
Discussion in 'Tech/Mech General' started by BASA47, Jun 29, 2016.
  1. BASA47
    BASA47 Funster
    Sep 18, 2011
    35
    6
    Coventry. England
    Hi I'm not sure if I was seeing things, I think I spotted on a Calpe Site in Spain a Site Hook up cable which seemed to have an additional connection for supplying an extension lead for outside power. It looked like it piggy backed the site mains Electric Hookup socket, therefor bypassing the Motorhome fuse box. When I went to speak to the owner, the next day they had moved on so I'm still not sure if such a thing exists.
    Has anyone else see these or did I have one drink too many????
    Basa
  2. NickNic
    NickNic Funster Life Member
    Jan 14, 2014
    5,759
    11,797
    Kettering
    Yep there are quite a few ways of doing it.
    • Thanks Thanks x 1
  3. matamoros
    matamoros Funster
    May 15, 2008
    2,408
    3,793
    Rochdale, Tavira, S. Brittany & Europe
    I have one, bought off ebay from Germany I think with the Schuko connection.
    We saw them quite often on the Continent, some are better than others regarding weatherproofing, there is a standard to which some adhere and some simply state 'weatherproof', ours falls into the latter category bur we have had no problems.
    Can't find one on ebay, maybe on Ebay Germany.
    • Thanks Thanks x 1
  4. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,135
    15,073
    Leeds the one up North
    • Like Like x 1
    • Thanks Thanks x 1
  5. FIDGET
    FIDGET Funster
    May 7, 2011
    2,929
    6,050
    Isle of Wight
    I presume you mean a mains splitter
    [​IMG]
    Leisure shop direct £12
  6. Techno
    Jul 28, 2010
    14,135
    15,073
    • Like Like x 1
    • Thanks Thanks x 1
  7. matamoros
    matamoros Funster
    May 15, 2008
    2,408
    3,793
    • Thanks Thanks x 1
  8. eddievanbitz
    eddievanbitz Trader - Funster
    Oct 4, 2007
    3,731
    11,580
    Taunton Somerset
    Not safe unless the bollard has its own RCD, Better touse an extension lead from the van which will be after the van RCD & MCB
    • Like Like x 1
    • Useful Useful x 1
  9. matamoros
    matamoros Funster
    May 15, 2008
    2,408
    3,793
    • Thanks Thanks x 1
  10. matamoros
    matamoros Funster
    May 15, 2008
    2,408
    3,793
    Every campsite bollard that I have used as a trip, is that an RCD?
  11. Techno
    Jul 28, 2010
    14,135
    15,073
    Many vans are not fitted with an RCD but I've yet to find a hook up point that wasn't protected
    • Informative Informative x 1
  12. NickNic
    Jan 14, 2014
    5,759
    11,797
    Kettering
    I know what they are.
    The ones with the socket on the female end of the connector, as in @Techno 's post do exactly the same thing, just at the other end of the cable.
    Whichever type they are all "simply splitters"
    The disadvantage of the female end type are that in the example the OP quoted - sharing a site or aire supply - you would need a further adapter to use it. With the male end type you can use your standard lead.
  13. Techno
    Jul 28, 2010
    14,135
    15,073
    With my two leads it works anywhere
    • Like Like x 1
  14. NickNic
    Jan 14, 2014
    5,759
    11,797
    Kettering
    Because you have a lead with a 2 pin plug that fits your adapter (y)
  15. Techno
    Jul 28, 2010
    14,135
    15,073
    Yes but it fits a shucko hook up post too
    Handy at places like Honfleur where electric has to be shared most often
    I've had others plug into mine with only a short lead
  16. NickNic
    Jan 14, 2014
    5,759
    11,797
    Kettering
    I've got a short (less that a foot) lead that will fit those with a blue socket on the other end. Never used it :(
  17. matamoros
    matamoros Funster
    May 15, 2008
    2,408
    3,793
    Yes I take your point about the term 'splitter' and the need for another adapter but the disadvantage of the types that you pictured is that you would need 2 hook up leads to reach the van and then still need an adapter to plug any appliance in.
    I have many continental appliances with Schuko connecters that I can plug in directly, I also have a short converter lead to a dual UK 3 pin socket outlet that i can use next to my van under the awning if necessary.
  18. matamoros
    matamoros Funster
    May 15, 2008
    2,408
    3,793
    Used ours lots, there are still lots of sites on the Continent with 2 pin sockets.
  19. NickNic
    Jan 14, 2014
    5,759
    11,797
    Kettering
    So I understand. That's why I carry one.
    I've just not found anywhere to use it yet although to be fair we usually pick aires over sites given any choice. Everywhere we've stayed so far that has had electric has just had the standard blue 3 pin connection.
  20. eddievanbitz
    Oct 4, 2007
    3,731
    11,580
    Taunton Somerset
    Loads abroad Andy, some using cartridge fuses? Also you reliant on the bollards working and being tested
    Safer from your own known supply
    • Like Like x 1
