Photograph recovery (1 Viewer)
ShiftZZ
21,383
84,495
Dark Side of the Moon
My dad, who is in his late 80's decided that he would delete all of his photographs from his laptop, they all went into the recycle bin and then he emptied the recycle bin...
Don't ask, I don't understand him either.
Now he has changed his mind, before I go down there are there any SIMPLE, FREE tools that I can use to recover the pics?
Ta
Jul 29, 2013
9,067
18,414
Salisbury
Hymer B678DL A class
since 2011
If you system restore to a date before deletion will they reappear?
Je ne sais pas! Just throwing at the wall to see if it sticks!
Think that should do the trick
Sep 25, 2012
522
1,228
West Cornwall
13 Years, 20 years with a caravan
System restore will not recover the deleted personal files. You will have to use a recovery programme like Recuva. The problem will be the more the PC is used the files could be overwritten.
Lenny HB
53,308
149,490
On the coast in West Sussex
Hymer B678 DL
You may be lucky with one of the recovery programs if he's not done much on the pc since deleting, there are professional recovery companies, but very expensive.
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
Go to http://www.recovermyfiles.com/, download the software and conduct a free scan on the drive they were deleted from.
If the scan locates the missing items you will have to pay for a licence key to unlock the recovery function of the software.
I've used it and it works - you get what you pay for.
The existence of this sort of software is why you should always remove the hard disc drive before selling a computer. It's based on the principle that files aren't actually deleted - all that happens is the computer's indexing system is told to 'forget' their location, but they remain stored there. They're only deleted when the disc space is physically overwritten with new files, which is why it's important to minimise the use of the computer until the recovery has been attempted.
TheBig1
17,592
43,009
that is what file shredding software is out there for. it deletes the file then randomly overwrites the disk space it took up multiple times. even government forensic analysts cant recover those files
Gellyneck
9,195
18,140
Scotland
More than toes wet now!
As said above, Recuva (free) is worth a try. Managed to salvage around 80% of photos from a similar occurrence on relations pc.
Broken Link Removed
Welsh girl
3,658
3,036
Globecar
Since 2004
So if your selling a pc, if you use the recovery disc and reset it to a state to when it was purchased, will all the 'old' files still be recoverable?
I got rid of an old pc once but removed the hard disc for fear of this.
I still have the hard disc and use it for storage.
GJH
29,450
38,827
None, now sold
2006 to 2022
It depends on how the reset process works. If it includes an equivalent of the file shredding software mentioned above then files will not be recoverable. If, however, it only overwrites that part of the drive which it needs to then files on other parts of the drive may be recoverable.
mid4did
526
727
N.somerset
Hymer Tramp R 655 GT
started in a minivan 1970's when I could fit into it.
as said dont write or install any more on the drive that also means dont install any recovery programmes using that drive as the boot drive.
You will have to take it out and use it as a slave on a pc or using a usb/sata or usb/ide connector to get best results.
I've had good success where a drive has been reformatted and even re-partitioned with getdataback for ntfs or fat partitions.It will take some time searching for lost or deleted drives and will turn up lots of unwanted files but you can use options to search for instance for *.jpg fies.
There are others but this got me out of trouble.
https://www.runtime.org/
