SOLD Phoenix Braked Three Motorcycle Trailer £690 (1 Viewer)
hashers2
20
6
southampton
c class
Please note- if you are interested in this trailer it has to be picked up on or before May 1st. It is currently located in Oxford.
For Sale £690
Phoenix Three Bike Braked Motorcycle Trailer which
cost new over £1,500 and includes a Fiamma lockable luggage box for helmets, leathers, tools etc which cost new in excess of £200
Full details can be found at https://www.phoenixtrailer.co.uk/
This is one of the biggest and strongest motorcycle trailers on the market. I have used it to tow two Harleys and a scooter behind our motorhome but it is equally suited to take three sports/dirt bikes to track days or events, or even a potential business opportunity transporting bikes around the country. Pre bidding Inspection welcome.
Construction is from 70 x 50mm, 2mm thick box steel.
The entire trailer is hot dipped galvanised.
Trailer rides on 155x12.8 ply tyres rated at over 1100kgs.
Includes:-
Spare wheel
Two galvanised walkways
Single Galvanised loading ramp.
Galvanised rear prop stands
Rotating telescopic jockey wheel
Specifications:- .
Overall length 13 feet (393cm)
Overall width 7 feet 1 inch (213cm)
Net weight 300kgs aprox
Max load capacity 1000 kg
Total Max weight 1300 kg
Will your bike(s), trike, combination or quad bike fit?
Max internal Width is 1.75m with rear steadies removed.
Max internal width with steadies 1.7m
The central runner is 2.16 m long (it is longer than the two side runners to stop handlebars clashing)
Two side runners are 2.0m long
All three runners are 25cm wide.
Distance from middle of hoop to back for side runners = 2.24m
The hoop on the centre runner is adjustable backwards and forwards giving a distance from middle of hoop to rear of runner of 2.26m or 2.48m (The Fiamma box will need to be removed to obtain max length)
All three runners can be moved sideways, everything is held down with U bolts.
All measurements are aprox. Give yourself room for manoeuvre.
As a practical example I have carried together:-
Harley Heritage Softail (Length 2.398 m Wheelbase 1.637 m ) on the central runner
Harley Sportster (Overall Length 2.275 m Wheelbase 1.515 m ) on the side runner
Kymco scooter on the other side
(See photo - Sportster missing)
There is minimal overhang.
43,319
49,386
What's even worse, the pic of the VIN plate shows its a 1000kg load capacity.
Gross weight 1300
Unladen weight 300kg
Deduct unladen weight from gross weight leaves 1000kg payload weight...minus the weight of the top box.
H
hashers2
20
6
southampton
c class
Yep Sorry. What happens when you do things when you are tired.
The weights have been amended.
