Peugeot Boxer Radio (1 Viewer)
smiffy502000
249
124
sutton coldfield
coach built.
since 2008
hi all. can anyone out there tell me if there is a way to over ride the 20 min cut off time on the radio in my Peugeot boxer without having to re wire it ? im sure I read somewhere that by pushing some buttons you can re set the cut off time?? help please
gazza280
97
355
Worthing
Since 2012
What year is the Boxer?
I didn't know about a 20 min cut off but I have a 2005 autocruise and instructions that might help.
paulmold
892
302
North Wales
7 year (25yrs a tugger)
You can't alter the pre-2006 radios without altering wiring but even that I'm not sure about as I've read that it's built into the radio not a feature of the wiring loom. Post-2006, you can go into the settings menu and there is a choice between 20 mins and 60 mins for the cut off. (I think on some it's called 'camper mode')
smiffy502000
smiffy502000
249
124
sutton coldfield
coach built.
since 2008
thanks guys. its a 2008 model autocruise stardream, ill have to have a look in the radio manual see how to get into settings...... that should be fun!! think mine is written in mandorin chinese
Paddywack
1,211
2,281
Neasham, Co Durham
Hymer ExsisT588
In ours (2014) solution is:
* Turn radio on using central ?power? button
* Within 15 seconds, simultaneously press ?FM AS? and preset button ?2?. Each
time this pair of buttons are pressed, the display will alternate between
?NORMAL POWER MODE? and ?CAMPER POWER MODE?
* Ensure that ?CAMPER POWER MODE? is displayed, then press ?MENU?
* Using the ?UP? and ?DOWN? button now changes the display to show various
adjustable items. Cycle through the options until ?RADIO OFF? and a number of
minutes is shown on the display. This will take approx. two presses of the ?UP?
button or seven presses of the ?DOWN? button.
* With ?RADIO OFF? shown on the display press the ?LEFT? or ?RIGHT? button. Each
press of either button will alternate the number of minutes shown between ?180?
and 180
* With ?180? showing on the display the setting is complete and three hours of
radio operation should be possible. Press the ?POWER? button to exit the menu
and return the display to its usual view.
Please note that in ?NORMAL POWER MODE? the same subsequent steps detailed above
can be followed, to choose between ?20 mins? and ?0 mins? of radio op
smiffy502000
smiffy502000
249
124
sutton coldfield
coach built.
since 2008
WOW thanks for that, I will try that later and let you know the outcome.. cheers
Mar 3, 2013
1,485
6,163
Poole
We wired ours directly to the leisure battery so even if we forget to turn it off it's no great shakes. The solar panel puts more charge back in than it uses anyway.
smiffy502000
smiffy502000
249
124
sutton coldfield
coach built.
since 2008
thanks for all your feedback, radio now sorted. took all of 2 mins, that has done my head in for 4 years !! cheers
Minxy
32,641
66,520
E Yorks
Carthago Compactline
I wish this worked with a non-standard radio!
Minxy
32,641
66,520
E Yorks
