Peugeot Boxer fan running
Discussion in 'Peugeot' started by Brian_K, Jan 5, 2016.
  1. Brian_K
    Brian_K Read Only Funster
    Feb 9, 2015
    272
    247
    Durham
    While doing some work in the MH today I could hear what sounds like a fan running, coming from the centre consul area. The sound is similar to that of a computer CPU fan.
    Strange thing is the noise only occurs when the keys are out of the ignition, put them in and light the dash board up, noise stops????
    Turn the key off and remove them, after about a minute the noise starts again.
    Could well be coming from under the bonnet, but it’s so wet at the moment inspection will have to wait.
    Does anyone know what this might be, I can book it in the local Peugeot dealers but though I would ask the question, to make sure I wasn’t doing something stupid.
    2015 X290 Boxer.
    Brian
  2. Allanm
    Allanm Funster
    Jun 30, 2013
    3,247
    4,415
    Cotes d'armor, France
    Never noticed a fan running like that in our Peugeot, but it's a 2013. But, I have a similar noise in my car. (Citroen C5) It's a fan running in the dash. I have a built in sat nav and radio/cd with Bluetooth, phone, and all sorts of computer gubbings, it appears to be coming from the radio unit.
  3. Brian_K
    Feb 9, 2015
    272
    247
    Durham
    That's what I thought. If it stops raining tomorrow :rofl: I'll lift the bonnet and see if more becomes evident.
    Whatever it is it's not using much electricity, cab battery is still fully charged.
    Brian
  4. Allanm
    Allanm Funster
    Jun 30, 2013
    3,247
    4,415
    When I turn my Boxer engine off, I can still here fans or motors running somewhere in the engine and a few clicks as they turn off. When I turn the Citroen engine off, I hear 3 or 4 electric motors or fans gradually running down, (sounds like 3 or 4 muted jet engines shutting down )Takes a couple of minutes sometimes for them to stop, then just as they do, the fan behind the dash (radio) starts up. It worried me the first time I heard it, but it went off after a few minutes. It does seem to run independently of the ignition though, and could be similar to what you are hearing
    • Useful Useful x 1
  5. Brian_K
    Feb 9, 2015
    272
    247
    Durham
    That's the one I think, but the cut off doesn't seem to be working (been running for several hours now). I'll book it in tomorrow at the dealers.
    Brian
  6. Allanm
    Allanm Funster
    Jun 30, 2013
    3,247
    4,415
    Ah, that doesn't sound right.
  7. Augusta08
    Augusta08 Read Only Funster
    Aug 25, 2015
    59
    37
    Morbihan
    We've got a fan in the battery charger that runs when on EHU if the charger is working hard, switches itself off/on with a mind of it's own.
  8. Brian_K
    Feb 9, 2015
    272
    247
    Durham
    Not sure where the fan noise was, but it was running 24/7 whether on EHU or not.
    I had it booked in at the local Peugeot dealer, but before going decided to give the MH a good run out. Got everything nice and warm and after 30 miles or so came home. Fan has never run again since, it now seems to have cured itself?????
    Brian
    • Like it Like it x 1
  9. Terry
    Terry Funster
    Dec 27, 2007
    10,784
    6,293
    South yorks
    Hi we had rad fan running on its own .kicked in after it had beenstood for about an hour---just turned on for no reason but luckily we were working in the van ---traced it to a relay rt slde of engine--swapping it with same relay out of Paul s van brought same fault on his van ---cured both with new relays
    terry
    • Informative Informative x 1
  10. aldhp21
    aldhp21 Funster
    Feb 17, 2009
    271
    1,126
    Cheltenham
    Hi @Brian_K . Did the fault with the fan running reappear? I've just noticed the exact same problem with my Fiat (2015 model)
    It sounds like a fan just behind the radio. No noise apparent from within the engine compartment.
    I've noticed that if you turn radio on and off, open either the passenger or drivers door, the fan noise stops temporarily but then comes back. We're heading up to Kilder this weekend so I'm hoping the long run up there will sort it out.
    Alan
  11. Badknee
    Badknee Funster
    Aug 25, 2014
    3,836
    17,173
    notloB
    Angela's C4 makes more noise with everything switched off than when it's running! Worried the hell out of me when we first got it but used to it now.
  12. ccr
    ccr Read Only Funster
    Apr 12, 2017
    scotland
    I have the same problem on a 2016 boxer cab Bailey motorhome, fan running behind the radio sounds like a CPU starts running approx 30 seconds after ignition switched off and keeps running indefinitely, until ignition or radio switched on again. Is this the norm from Peugeot or is there a fault and fix for it.
  13. Vanderek
    Vanderek Funster
    Feb 14, 2009
    153
    96
    Chandlers Ford, Hampshire
    I read some where on the forums that if you hold the off button it should fully turn off radio rather that go into stand by.....my radio decided to change all menus to Italian despite changing to English and saving then the next day it was Italian. The fix is open the driver's door then close it. It revered to English :rolleyes:
