Peugeot 107 Urban tug-along?????
Discussion in 'Motorhome Accessories' started by Trikeman, Nov 2, 2013.
  1. Trikeman
    Trikeman Read Only Funster
    Aug 22, 2012
    1,525
    2,756
    North Somerrzet.
    Hi All,
    I can remember this being talked about before, but alas unable to find it.
    I see lots of Peugeot 107s (and similar) being towed on A frames and I have a chance of buying one with an A frame, however it is the Urban version - semi-automatic. The guy selling it says its fine and he has towed it for quite some time.
    I have tried to get information as to whether this specific version (the semi-auto) can actually be towed without 'fubaring' the gearbox - some say yes, some say no - and that includes speaking to Peugeot dealers too. Some of the A frame co's say its OK as "they fit lots of them", that could mean the 'semi' (as in auto) may mean it's actually not a normal auto. I don't want to tow it if it's not suitable.
    Does anyone have any info that may help?????
    Thanks,
    Trikeman.:Wink:
  2. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,810
    39,356
    We "A" framed a peugeot 107 manual, and have now changed to a Toyota Aygo... both manuals..
    I like the Auto,,,, but was warned off .. some say not suitable, some say OK... but rather than take a chance we went manual..:thumb:
  3. keith
    keith Funster
    Aug 25, 2007
    3,285
    1,671
    Ecclefechan
    We own a 107 and have towed it on an A frame many miles without any problem. I was told there would not be a problem and that has proved correct.
    Technically I understand it there is no torque converter as in a normal auto, changing gear achieved by electronic means, which is a very different auto box, called a Triptonic - if remember rightly.
  4. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    the tiptronic same as the sprintshift in the merc I believe a manual gearbox with hydralic clutch, so can be used as an automatic or manual and as far as I know tows fine because it has no torque converter.
  5. s20hymer
    s20hymer Funster
    Jun 11, 2011
    274
    331
    Wiltshire
    peugeot 107 urban
    I have towed my semi auto peugeot 107 for 1000's miles,behind my hymer motorhome, although it is semi auto it has a clutch and the gears are changed electrically, you must make sure the car is in neutral while towing, you need a key in the ingnition to release the steering lock, I bought a blank peugeot key with no electronics in it from ebay, I then took it to the local keycutter to be made to the same spec as the original . I would advise you lock the car with your proper key so that no-one can get in i.e. at traffic lights. Another thing I do is use a padlock in the h oles where the a-frame attaches to the car so that the a-frame does not get stolen. Regards, Mike
    • Like Like x 2
  6. Trikeman
    Aug 22, 2012
    1,525
    2,756
    North Somerrzet.
    Good advice above - Thanks.
    Well after much advice we have gone ahead and bought this little gem.:Cool: Drives well and complete with a Towtal system.
    Piccy.
    [​IMG]
    We hope to get about a lot more now with this little bus on the back.
    Regards and Thanks.
    Trikeman. :Wink:
    • Like Like x 1
  7. DJA
    DJA Funster
    Mar 5, 2011
    301
    245
    A Frame
    Hi Trikeman
    Wishing you many happy hours towng. We have a Toyota Aygo Automatic and it is great to be able to nip around to places you could not take the Van easily.
    Regarding the Key we got a replacement key from the Dealer we got the car from but asked them not to electronically match it to the car. This enables you to turn the key to the first notch to release the column lock. If you turn the key fully it will turn the engine over but it will not start.
    One other little tip is if you stop for a while check that the brake lights are not still on draining the cars battery. We have had it happen.
    Interestly enough whilst the Aygo auto can be towed the Toyota IQ auto can't.
    Enjoy.
    Doug
  8. s20hymer
    s20hymer Funster
    Jun 11, 2011
    274
    331
    Wiltshire
    replacement key for peugeot 107 without electronics.
    200981074536 place on ebay to go for substitute key, less than £3 including postage, would have cost me nearly £40 from dealer, your car looks lovely, hope you have lots of pleasure from your new "Toad", ours is called "The Nana", the grandkids think it looks just like a banana with its bright yellow colour. P.S. we have bought the mifi as per Minx thread, brilliant. :thumb:
