Permanent Mounting Bracket for 11kg Refillable Gas Bottles (1 Viewer)
WhereNext
24
Australia
Carado T135
Since 1981
Has anyone any suggestions for permanent mounting brackets (inside a gas locker with external door) for securing an 11kg refillable Gas Bottle?
The ones I have seen seem to have bolts to secure the bracket suggesting the need to drill through the walls of the locker. Given the gas locker is suppose to be air-tight to the habitation area how have others addressed this problem (sillicone maybe?) Would appreciate your thoughts.
Bart
3,188
1,398
Northern Ireland
Boxer L4H2 van build
Since 2016
If you get a Gas leak the gas will sink to the floor first of all as it is heavier than air , hence the vents in the Floor of the gas locker , but for peace of mind when i drilled our locker side wall i used a small blob if sealant to seal around the drilled holes.
Lenny HB
53,408
149,868
On the coast in West Sussex
Hymer B678 DL
I don't understand why you need to change the mounting nearly everyone uses the standard straps without any problems.
W
WhereNext
24
Australia
Carado T135
Since 1981
My van is german registered where refillable bottles require permanent mountings, loose straps aren't sufficient.
Nov 4, 2011
5,936
38,890
Uk
I have Gaslow and have used hook bolts that hook on the bottom flange of the bottle and then go through the gas looker floor.
I will post photos later.
Lenny HB
53,408
149,868
Hymer B678 DL
Is this what you have been looking at , I can't see how mounting these would be much different to mounting the material strap retainers, the likelihood of gas escaping through the mounting very unlikely.
Nov 4, 2011
5,936
38,890
Uk
This is how I fixed mine.
W
WhereNext
24
Australia
Carado T135
Since 1981
@Lenny HB those ebay straps look promising as do @Manic solution.
As I'm waiting for delivery of my van in May, could anyone tell me how wide most of the fabric straps are? (I'm wondering if I could simply replace the exiting fabric straps with GasIT Universal Straps, here:
Thanks again everyone!
Lenny HB
53,408
149,868
Hymer B678 DL
Just had a measure, 20mm on my Hymer, that blows that theory out.:cry:
