Paying for Electric and water
Discussion in 'France' started by scotty1, Mar 23, 2015.
  1. scotty1
    scotty1 Funster
    Mar 10, 2010
    203
    34
    Kent
    in my new All the Aires bookes i read that you pay for 1 hr of lecy to charge battery.how much will it charge your battery in 1 hr ? Thanks guys trying to get as much in my head as poss for next wk.Scotty
  2. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,991
    1,993
    Warwickshire
    As I said in reply to your earlier post about aires, the electricity facility is really little more than a top-up unless you are prepared to keep feeding the meter. Also bear in mind that you may not be popular with the locals if you hog the EHU point. Having said that, it is not uncommon to find several vans hooked up to the same point using branch connectors. The French Camping Caristes tend not to use EHU in the same way as many Brits do on a camp site. They do not depend on it for general power (sockets, heating etc.) but simply use it to give the leisure batteries a boost.
    Regardsing what you might get in one hour, it will depend on the size and type of batteries you have and the power of your charger. Most motorhomes have chargers with an output in the range 15-20 amps so in an hour, you could in theory put that into a battery. In practice it does not work quite as simply as that and you will get a bit less. Also, if you have gel batteries, they charge much more slowly than a wet lead-acid type. I think AGM batteries charge at about the same rate as a wet battery.
  3. scotty1
    scotty1 Funster
    Mar 10, 2010
    203
    34
    Kent
    JeanLuc many thanks.
  4. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,991
    1,993
    Warwickshire
  5. sallylillian
    sallylillian Funster Life Member
    Oct 29, 2011
    1,137
    674
    Falmouth, Cornwall
    In terms of voltage AGM's are in a similar range, but you do need to consult the battery manufacturer’s manual as they are much more susceptible to over voltage. However the big advantage is that they can take 2 or 3 times the battery’s total amps in bulk charge. So if you have a 200 amp battery then you could charge at circa 14.4 volts (temp dependent) at 400 to 600 amps, again check with the manual. Of course there are not chargers of this size in common use. I had 2 100amp chargers in parallel on my boat feeding a huge Lifeline AGM bank and regularly saw nearly 200 amps when on bulk charge, so if you install AGM's consider your charger options too to get the most of the bank's ability.
  6. FIDGET
    FIDGET Funster
    May 7, 2011
    3,037
    6,223
    Isle of Wight
    Hi Scott1,
    Don't know how long you are planning to go for, or how long stopping in one place, we tend to move on each day , touring doing a reasonable amount of miles each day and have never needed to charge the battery any extra.
    Also bear in mind about reverse polarity, we once stopped on a municipal c/site electricity in the price , connected up and it caused the fuse to blow in the control panel (bugger) , since then we have bought a reverse polarity checker
    • Like it Like it x 1
  7. scotty1
    scotty1 Funster
    Mar 10, 2010
    203
    34
    Kent
    Thanks Fidget
