Partial Re-wire Urgently Required (1 Viewer)
Gerard Saunders
30
3
Battle
11 years
Hello. I am looking for someone who can replace the charging system on our 2003 Knaus Sun Traveller. It has a Calira system at present.
We purchased the vehicle from a dealer in June and subsequently discovered some faults. We love the layout of the vehicle and it has a very low mileage, so before we go down the painful road of seeking a refund of the price we paid I would be grateful to hear from someone who might be competent at working on these things, beyond just testing and replacing components.
I envisage a new charging system being installed, following which existing components, water gauges etc. would need to be wired in using appropriate connectors. It is my understanding that the existing control unit cannot be repaired. (I have tried the chaps in Wales!)
I am not looking for a cheap fix and fully appreciate that the job would be time consuming. Thank you in advance for any pointers. We are based in East Sussex but are happy to travel.
Regards, Gerard Saunders
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
It's not rocket science by a long way so don't panic. These people can supply all the parts, give them a ring and ask if they know technicians.
Link Removed
http://www.magnummotorhomes.co.uk/en/
And of course, good old Johns Cross is near you.
Feb 27, 2011
14,732
75,862
UK
Self Build
I would second the VanBitz recommendation. His work is second to none and will be of top quality. Might need to book in quite a bit ahead of time as he is in high demand.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Is it just not charging on EHU?
The Mother in Laws Calira packed up in such a way and I simply grafted in a Durite 20 amp 4 step charger, leaving the Calira unit in place.
Total cost about £95.
Gerard Saunders
Gerard Saunders
30
3
Battle
11 years
Thanks for the encouragement, but I assume you had to analyse all the internal wires to panel, meters etc. then connect to appropriate pins on the new charger?
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
No, look under the Calira box and all the plugs are labelled.
Pick the positive to the leisure battery and tap into that with the charger positive output. Chose a common negative cable for the charger negative output.
Then remove a 240v output plug from the Calira box, split it, and parallel the charger supply out of that. Reassemble the plug and replace it in the socket in the Calira unit.
Everything works then,as it should, without replacing all the 12v distribution.
Jul 5, 2013
11,723
13,701
Since 2013
Given that you live in East Sussex you could try Johns Cross on the A21 North of Battle. Very good service from my experience
But why isn't the dealer you bought it from sorting it out as he is required to under receny legislation?
Gerard Saunders
Gerard Saunders
30
3
Battle
11 years
The dealer has agreed to pay for the work. As ther are 250 miles away this seems the best solution.
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
maybe if you explained what is actually not working rather than seeking to start from scratch you might get better advice
most motor home system comprise of a charger /power supply a split charge relay a fridge relay and a few switches and gauges
usually over complicated by a digital user interface these days all the parts can be replaced or piggy backed as a repair
JockandRita
11,462
150,078
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
@funflair (Martin) has a contact for a one man band who repairs leisure charging units.
It might even be this one, which came up from my bookmarks.
http://www.leisureelectronicrepairs.co.uk/
I must admit, I like the sound of the repair which @jonandshell described above :) especially if the original unit cannot be repaired, although I might not be happy about attempting to do it myself, ie, unsupervised. ;)
Good luck with it @Gerard Saunders. (y)
Cheers,
Jock. :)
funflair
19,334
30,178
Guisborough
MORELO palace
since 2012
Cheers,
Jock. :)
Don't think I have Jock.
Martin
Jan 19, 2010
206
148
Pembrokeshire
Glad you've got it sorted, but should anyone else be in the same position these folk claim to be able to do repairs: http://www.aandncaravanservices.co.uk/calira.php
I 2nd that. Alan got us out of the mire a week before our trip to France last year. He went out of his way to get us sorted and charged far less than he could have.
Reactions: DBK
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
OK apart from original post...........
