Panel Connection Advice
Discussion in 'Solar Power' started by jac-in-a-box, Jul 6, 2015.
  1. jac-in-a-box
    jac-in-a-box Read Only Funster
    Sep 9, 2014
    161
    95
    All my bits and pieces are here and I now have time to crack on albeit I'll not get it all done in a day...'tis forecast foe rain in the morning
    I've got two 150w panels ready to mount and it shouldn't be difficult to get the cables through the roof and up to the controller. While I don't believe I need them, I've got a fuse block fitted just before the controller ( that is, between panels and controller)
    If I leave the fuses out and connect the cables between panels and controller, do I need to leave the panels covered, if uncovered will I do damage? My thinking is that the fuses will act as a switch...and my temporary cardboard cover ain't going to last too long in this weather!
    As always, your advice is appreciated :)
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,252
    17,923
    YO11 2BD
    The voltage between panel and controller can be between 17volts and 24volts......a 12v fuse wont last long.
    place the fuse as close to the battery as possible instead.
    To work on the wiring simply wrap some insulation tape around the open ends of each panel wire, removing only to make final connection....one at a time.
    As long as the bare wires dont touch no damage will happen to the panels...covered or not.
    • Like it Like it x 1
  3. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,279
    3,086
    Kendal, Cumbria
    Not true - voltage is irrelevant to a fuse. Just fuse slightly above the panels rated output in Amps. Your solution is fine - just connect the controller to the battery before you put the panel fuse(s) in. Shorting the panel output, although inadvisable because of likely sparks, will not damage the panel. Using your method this won't happen anyway.
  4. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    sorry John a fuse is current not voltage rated, oops Tony beat me to it.
  5. jac-in-a-box
    Sep 9, 2014
    161
    95
    Thank you all for the replies...pappajohn you threw me with the voltage related fuse's; caused a few head-scratching moments!
    Good to know I'm on the right track for the first step, appreciated:)
    If I can pick your brains again please. Once I get the whole thing cabled up (there will be fuses at leisure batt's) would the correct "switching on" sequence be:
    *Fit fuses between leisure batt's and controller
    *Fit fuses between panels and controllers - my "switch"
    In the event the sun is shining, is it advisable to cover panels before inserting fuses between panels and controller...just thinking the panels will be be producing power and want to avoid any little accidents!
  6. jac-in-a-box
    Sep 9, 2014
    161
    95
    Should've read response's more carefully regarding the fusing up sequence...Tony's reply answered my last question, thanks!
