Painting ceiling or something more
Discussion in 'Tech/Mech General' started by movan, Jul 2, 2016.
  1. movan
    movan Funster Life Member
    Dec 2, 2009
    14,481
    26,888
    Moving around
    Don't know if this photo shows problem.. I have a dark mark showing on ceiling of van along the metal strip. First thought was that there was a leak but it appears to be dry. Second thought is that maybe last owner tried to glue the metal strip even tighter to ceiling and made a mess.
  2. Smith and Sharp
    Smith and Sharp Funster
    May 31, 2015
    1,803
    2,873
    Cornwall
    Do you know what the ceiling is made of Joy, ? Is it plastic coated or papered hardboard ...?
  3. vwalan
    vwalan Funster
    Sep 23, 2008
    7,799
    4,082
    roche cornwall
    possibly eggshell finish or bathroom paint usually works .
    • Thanks Thanks x 1
  4. movan
    Dec 2, 2009
    14,481
    26,888
    Moving around
    I would say papercoated hardboard but it seems better finished than that so maybe a plastic type paint .. sorry, I am rubbish at this.. think it hardboard with grey sort of paper on it.
  5. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,366
    14,498
    Bolsover, Derbyshire
    I am really sorry to say Joy, my fear is that it is damp, or at least was
    personally I wouldn't paint it, research changing the roof panels first, it could look every bit as bad painted badly (y)
    have you asked Terry what he thinks yet?
    • Thanks Thanks x 1
  6. Smith and Sharp
    May 31, 2015
    1,803
    2,873
    Cornwall
    Although @DavidG58 is right in saying that a replacement panel is best rather then painting I don't think it is damp, I've seen glue go like that before and turn a horrible brown colour.
    Painting will be cheaper but it will look painted and once painted will need painting more frequently... But if you do then as mentioned an eggshell would be best ....(y)
    Good luck...:)
    • Thanks Thanks x 1
  7. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,958
    23,794
    Narrfoook
    Me being a natural born bodger, I would look at covering it with a bit of decorative trim tape..
    Advantage being it is cheap, easy to do and if it does turn out to be a more serious problem can easily be removed
    After thought..
    Have you tried just cleaning it ? Perhaps use a drop of pure alcohol ( I use the stuff for all sorts nowadays after buying a bottle to clean off some tree sap.. It seems to work on all sorts of stuff ! )
    • Like it Like it x 1
  8. rb62
    rb62 Funster
    Nov 5, 2013
    555
    7,929
    Shropshire
    The problem with most modern paints is that they are water based and are very poor at covering staining.Ther are some good stain blockers available but they give off nasty fumes! so you would need somewhere to sleep for a night or two.I did the ceilings in mothers bungalow with this.But you would need to check you could use it on plastic covered panels.
    2016-07-03-09-26-33-1503430300.jpeg you can put it on with a roller
    • Thanks Thanks x 1
  9. movan
    Dec 2, 2009
    14,481
    26,888
    Moving around
    Hi John, Yes I tried to clean a little area ........... and made it look even worse, dirtier. :( .. Will think about the tape idea .... or better still just not look upwards ;)
  10. trophychap
    trophychap Funster
    Dec 24, 2009
    739
    6,589
    bedworth warks
    I don't want to scare you Joy but if it was me I would have someone with a damp meter check that out, it looks suspiciously like damp staining to me from your photo. I hope I am wrong.
    We had a new Bessacar in 2009 that had a leak round one of the roof lights it was picked up by the dealer and fixed, the stain looked very similar when it appeared. But those nice people at Swift insisted we took it back to the factory and they re papered the roof, we were finding splodges of wallpaper paste on the cupboards for weeks after we got it back LOL.
    Its some type of Vinyl wallpaper that's used.
    • Thanks Thanks x 1
  11. movan
    Dec 2, 2009
    14,481
    26,888
    Moving around
    Thank you. Will get my damp meter on it when I get back home before I decide what to do.
  12. Smith and Sharp
    May 31, 2015
    1,803
    2,873
    Cornwall
    I think the vinyl paper route is a good one, I didn't think of that earlier..(y)
  13. Allanm
    Allanm Funster
    Jun 30, 2013
    3,292
    4,504
    Cotes d'armor, France
    Check it's not damp first, then how about covering it with vinyl wallpaper from somewhere like B&Q. I just re papered the bedroom in our van, nothing wrong with it, just wanted a plain colour. About £12 a roll from the above mentioned shop.
  14. Terry
    Terry Funster
    Dec 27, 2007
    10,807
    6,321
    South yorks
    I will be 3 mm ply covered with vinyl paper Joy -Don't do anything until we meet and I will investigate it for you ;)
    terry
    • Like it Like it x 3
  15. movan
    Dec 2, 2009
    14,481
    26,888
    Moving around
    Hi Terry .. It is the same stain I already showed you and you said ignore it. . But it grates me when I clean up so I thought I might paint it. I will put my damp meter on it and then decide if I can live eith it. I don't want to do anything that makes it look like a coverup job.. would rather just avoid looking at it :(
  16. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    1,815
    3,470
    Cumbria
    If, starting at one end, you prise out that central plastic strip, that will give you access to the screws that hold the half round moulding on. Take that off then have a better look at things. The trim just covers the junction between the fabric type headlining in the cab area and the 'papered' ceiling of the hab area, they may even have run a couple of cables through it too. I doubt it's damp related though.
    • Thanks Thanks x 1
  17. Terry
    Terry Funster
    Dec 27, 2007
    10,807
    6,321
    South yorks
    If same stain and I was not concerned. Then I will give it another look in a couple of weeks
    You can always stencil flowers there to blend in with you're Hippie mate's
    Terry
    • Informative Informative x 2
    • Funny Funny x 1
