Painting A Tow Bar - Help / Info (1 Viewer)
tonka
10,823
21,514
Cannock, Staffs
A class Burstner 800
Since 2000
My plastic covered (PWS) towbar has grounded a few times and was in tatty condition..
Removed from van, plastic all cut off and I have cleaned up the bar..
Cheapskate that I am :) Tin of Hammerite white paint, paint brush and gave it a couple of coats..
RESULT.... It's ok but streaky and obviously a "hand job".
SO,,, Whats my next option ?? Do I use some fine sand paper or what's this "wet and dry" stuff...
Body repair not my speciality..... Urgent job as I need this back on for Monday so I can bring my bike to Stratford.. Got B&Q, car spares shop, Halfords and a Screwfix all on door step for any supplies...
Awaiting Funster advise..
Oct 18, 2014
1,858
1,157
Salisbury
Hymer B598 PL
Since 2013
Spray with Matt black body paint' resistant to mechanical damage, that has epoxy resin or rust inhibitors then polish up if needed
funflair
19,294
30,058
Guisborough
MORELO palace
since 2012
Well if it's got a couple of coats of "hand job" it's obviously protected so now you just want the bits you can see to be nice, "wet and dry" is as it suggest a sandpaper that can be used wet or dry but wet will stop in clogging even better with a bit of fairy in the water, give the streaky bits you see a rub over with 400 grade on a soft block and then spray with a can of white Hammerite.
Martin
tonka
tonka
10,823
21,514
Cannock, Staffs
Since 2000
Martin
Thanks... 400 grade - fairy liquid... See that's the bit's of info I need. :)
Aug 18, 2014
23,739
133,171
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
You've obviously used the hammerite "smooth" as if you'd used the original it dries as a "hammered" finish , hence the name, & doesn't show brush marks.Thinking about it the smooth shouldn't either.
tonka
tonka
10,823
21,514
Cannock, Staffs
Since 2000
I hovered for 10 mins looking at smooth / hammer finish and went with smooth..
We use hammerite on our garden gates etc and although it does go on a bit rough, when dry shows no marks..
Maybe I got a duff tin :( even bought new brushes..
Well it's back on the van now as forecast heavy rain later.. I will get some wet and dry as mentioned by Funflair and give it a try after Stratford...
Gellyneck
9,194
18,137
Scotland
More than toes wet now!
When a tugger used hammered finish on towbar bracket \ backplate \ etc and it looked excellent. Bit like a glossy resin coated finish. no brush marks, etc.
musson
487
165
grantham
low profile
since Jan 2014
try spray hammerite or rustolin spray paint comes in all colurs
buckby
213
147
nottinghamshire
coachbuilt
I have just done mine sanded down to bare metal and used white smooth hammerite with a small foam gloss roller it is a slightly stippled finish but looks excellent if you use some 120 grade paper on a orbital sander to get rid of the streaks and get the finish smoth then over paint with the gloss roller it should look good hope this helps
tonka
tonka
10,823
21,514
Cannock, Staffs
Since 2000
Cheers everyone... Gonna have a go when back from Stratford, it's back on the van and looks ok from a distance but will try to improve it when i get home...
SUGGY
1,311
2,201
scunthorpe
my paint job on the tow bar is the same .
i think it is because the bar is bare metal and the Smoothrite dose not have any rust / rough surface to stick to
Look on the bright side it will go rusty again, then you will have a surface for the paint to stick to ..:coolest:
