Paint for plastic
Discussion in 'Motorhome Chat' started by mikekaren2, Apr 7, 2014.
  1. mikekaren2
    mikekaren2 Funster
    Dec 5, 2013
    314
    246
    Somerset
    Has anyone successfully painted the internal plastic door liners, my Hymer door liners are yellowing. I have cleaned them but I would like to paint them white again. Any suggestions, I would prefer to brush paint but I could spray them at a push.I just need to know what brand plastics paint works.
    Thanks.
    Mike
  2. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,920
    1,944
    Warwickshire
    So are mine (yellowing). My advice would be to leave them alone. I think there is a high probability of a paint job looking like a bodge and unless you paint every bit of white plastic inside the van, the door will stick out like a sore thumb. The other sections I am thinking of are the pull-down bed under-tray and the door edging strips. Then there is the shower room which is also likely to yellow.
    I have resolved to live with it.
  3. kaasbroodje
    kaasbroodje Funster
    Sep 14, 2013
    792
    894
    Bristol
    I think that the yellowing is a Hymer characteristic, no idea why..
    I do agree that it's best left alone though.
    Scan through the classified ads, so many attempted 'improvements', they rarely look good !
  4. mikekaren2
    mikekaren2 Funster
    Dec 5, 2013
    314
    246
    Somerset
    Plastic paint
    That's what I want to avoid a bodge job, unless someone has successfully repainted plastic I will live with it.
  5. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,687
    23,082
    Narrfoook
    You can use almost any paint by adding a plastisizer to it..
    We use two pack and acrylic
    If you google acrylic plastizer you should find what you need :thumb:
  6. TheDeckKing
    TheDeckKing Read Only Funster
    Aug 10, 2014
    138
    119
    Hyde, Cheshire
    Have a look at Zinnser BIN and 123. They will stick to anything, can be left as a finish or over coated.
    • Like it Like it x 1
  7. Kool Kroozer
    Kool Kroozer Funster
    Apr 19, 2014
    1,222
    2,040
    Cannock Staffordshire
    Can you not bring it back by using cream cleaner ?
  8. meanders
    meanders Funster - Life Member Life Member
    Jun 28, 2008
    571
    344
    Ipswich, Suffolk
    Not cream cleaner, but plastic colour restorer as used on cars may do the trick. Alternatively baking soda mixed with water to a paste and gently rubbed on may restore the colour.
  9. Peter_n_Margaret
    Peter_n_Margaret Read Only Funster
    Oct 27, 2013
    87
    62
    Adelaide, Australia
    Yellowing of plastic is usually caused by UV light (sun). The plastic is breaking down.
    It is easily protected against by the manufacturer by using decent UV inhibitors in the plastic. Not doing so would save them a couple of cents per part, so there is no real excuse.
    Whether it can be painted easily, or not, really depends on what type of plastic it is.
    Polyethylene and Polypropylene and both nearly impossible for DIYers to do well. Paints will just fall off. They can be treated professionally, but that is unlikely to be an economic proposition.
    Some other plastics are easier to handle. PVC and ABS can be painted readily, but you must know what the plastic is before you start and select an appropriate paint.
    Cheers,
    Peter
  10. tambo
    tambo Read Only Funster
    Jun 21, 2014
    875
    637
    Dunfermline fife scotland
    Painting plastic is easy go to your local spray paint shop and get a tin of plastic primer which you spray on first then spray with ordinary spray paint
    I've colour coded the mirrors the door handles and all my exterior vents to the white of the van ......
  11. BwB
    BwB Funster Life Member
    Apr 3, 2011
    608
    563
    Brandon Suffolk UK
    Have a search on YouTube - lots of info (some good some not so good) but you might spot something worth trying before going down the painting route.
  12. andy63
    andy63 Funster
    Jan 19, 2014
    2,226
    8,524
    south shields
    id be a bit more cautious than that... some plastic paints well,,, car bumper and nowadays without any primer etc just straight out aerosol.. but agree with with peter, depends on the plastic..
  13. tambo
    Jun 21, 2014
    875
    637
    Well I've been doing it around 24 years now :) 6 show winning vw campers
    And the stuff I've done has always worked out fine :)
  14. andy63
    andy63 Funster
    Jan 19, 2014
    2,226
    8,524
    south shields
    good on you ive had a few disasters with some plastics even with the plasticizers and plastic primers....
    hey I just took first place in the camper category at transitmania... not in the same league as you but black plastic trim and other colour coordinated plastic bits including my sat dome (which on best advice shouldn't be painted but seems to work just the same ..
    ta andy .ps the van has been changed since avatar photo
  15. rangitira
    rangitira Funster
    Jun 30, 2010
    6,440
    13,411
    Cornwall
    Highly recommended, I've used it before, dries in 7mins, you can paint it over literally anything, and put anything over it. Make sure the can has been properly stirred
    This is the can with the red markings not the blue! Red is spirit based, blue is water based and crap.
    Word of warning tho be well ventilated, I used it a lot and used to have a large fan pointing out the door blowing the fumes out.
    Another tip, on the top coat, (over the Zinnsser BIN 123) use a small sponge roller, it'll give you a finish similar to a spray gun
  16. TheDeckKing
    Aug 10, 2014
    138
    119
    Hyde, Cheshire
    The red BIN is shellac based. With the price of shellac going through the roof Zinnser has spent a lot of money improving the 123 and you can also get a 123 plus. These now stick to more surfaces than the BIN. I know it seems counterintuitive but I'd recommend the water based 123 for plastic with a decent quick dry eggshell over the top.
  17. tambo
    Jun 21, 2014
    875
    637
    Spray can plastic primer £7 ...and aerosol white
    Cheap and best finish
  18. tambo
    Jun 21, 2014
    875
    637
    Yeah I kinda got carried away with mine over the years , lost count how many thousands I spent ....i sold my split screen camper in 1998 and bought my first flat outright with the money lol.
    I then moved on to t25 and finally t4s and towed caravans .....then tired of the stress bought a motorhome ....just can't lose the modifying streak though :)
  19. andy63
    andy63 Funster
    Jan 19, 2014
    2,226
    8,524
    south shields
    you liked your vw then.. done a little work on the early engines for a mate once, best I can remember never quite stopped the oil leaks though lol
    on the cost front id be embarrassed to say what I spent putting the transit (a pill to convert anyway) together, certainly couldn't get my money back selling it as its a bit of a one off to suit my needs...
    you a mechanic by any chance??
    ta andy
  20. tambo
    Jun 21, 2014
    875
    637
    I was i did it for around 8 years then fancied a change , did welding for a while then powder coating , metal fabricating and then moved on to factory work im now a charge hand for a shopfitters :)
    Means I can turn my hand to most things these days thankfully
