Oyster dish problem !!!
Discussion in 'Tech/Mech General' started by Stephen & Jeannie, Nov 14, 2013.
  1. Stephen & Jeannie
    Stephen & Jeannie Read Only Funster
    Aug 27, 2008
    4,198
    3,262
    Gobowen near Oswestry !!
    Trying to put the dish up and am confronted by this message on the panel along with a flashing red light !:cry:
    V motor blocked !:Doh:
    Any ideas, or suggest someone in the Shrewsbury area who could fix it !:Sad:
  2. martin1485
    martin1485 Funster
    Jan 26, 2010
    446
    669
    Conwy, North Wales
    A call to the importers may be the quickest way to identify the fault?
    Oyster Sat-Tech Ltd.
    Unit 5, Hemploe Business Park
    Hemploe Road, Welford
    Northants, NN6 6HF
    Tel: 0044 1858 575 928
    Fax: 0044 1858 575 028
    e-mail:
    info@oystersat-tech.co.uk
    www.oystersat-tech.co.uk
  3. Ash
    Ash Trader - Service & Repairs Life Member
    Sep 22, 2007
    770
    195
    The Midlands ( Nuneaton )
    Give this chap a call at Oyster Names Anthony 01858 575928 :thumb:
  4. Vlad The Impaler
    Vlad The Impaler Funster
    Apr 22, 2012
    1,623
    2,193
    Rutland
  5. Daiboy
    Daiboy Funster
    Sep 21, 2012
    64
    105
    Swansea
    Is it possible that it did not retract 100% last time it was "parked". If this was the case then until it's reset it cannot do anything.
    There is a way around this that requires 2 people, 1 on the roof and 1 on the controls. On the roof slacken the 2 bolts that attach the dish to the mechanism. When the dish is set to open on the control box, the person on the roof raises the dish manually. Once this has happened press the main switch inside to stop the action.
    Meanwhile put a small piece of wood approx 5mm thick under where the arm and dish come to rest. Switch the unit back on and it should open up properly, without tightening the dish nuts retract the dish and allow it to come to rest on the piece of wood. Reset the dish to its original retracted position and tighten the nuts. If this was the problem, job done.
    I assume that you have removed the main fuse from the oyster control box (it's normally red) counted to 5 and refitted it. This sets everything back to the default factory settings so you'll need to retune. This works in lots of Oyster faults.
    To avoid any possibility of flack. I'm no expert on Oyster or any other Satelite systems but have seen these procedures carried out with success. I accept no responsibility but you could save yourself a few bob.
    Daiboy
    • Like it Like it x 1
  6. Stephen & Jeannie
    Aug 27, 2008
    4,198
    3,262
    Exactly the case, it's not down fully, just a couple of inches out !!:cry:
    Had a look at the control panel and can't see how to get in..:Do
  7. Stephen & Jeannie
    Aug 27, 2008
    4,198
    3,262
    Many thanks one and all !!
    Finally found the fuse, but no joy there !:Doh:
    I am not up to scrambling around the roof at my tender age so a trip to Jackson Satellites is called for to have it done under the guarantee and have it re jigged for the new satellites coming on stream !
    Thanks for all your replies and suggestions !:Cool::Cool::Cool:
  8. MikeandCarolyn
    MikeandCarolyn Read Only Funster
    Mar 18, 2008
    2,171
    1,463
    Worle,North Somerset
    Hope you get it sorted Steve :thumb:
    From the thread title I thought it woul be another cooking thread :Rofl1::Rofl1:
    Mike
  9. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    new transponder fixes unlikely to be completed before Christmas so no rush.
