Oyster Digital Not Finding Satellite
Discussion in 'TV & Satellite' started by SandraL, Jun 27, 2015.
  1. SandraL
    SandraL Funster
    Jan 24, 2012
    329
    163
    Somerset
    My dish just spins and cant find astra2 satellite, a phone call to Oyster , 01858 575 928 produced quick answer that I needed to download new software, instructions arrived via email within 5 mins. Followed instructions and all was well. Idea is to point it at Astra 1, download and thats it. 5 star treatment from Oyster. Ours is a 2 year old digital system. There was no inputting of info apart from a code number which Oyster provided in the instructions.
    • Like it Like it x 2
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    nice to see such a quick solution.
  3. dpsuk999
    dpsuk999 Funster
    Jun 6, 2012
    343
    308
    Leeds
    Hi, could you post the instructions for the benefit of others who may come across their oyster system not finding Astra2
    Regards David
    • Like it Like it x 1
  4. SandraL
    SandraL Funster
    Jan 24, 2012
    329
    163
    Somerset
    OK, I couldnt upload the file, possibly as now an odt file? ( still a luddite) so have cut and pasted it, hope its all there........
    Oyster Digital/Internet update and Internet setup procedure
    The following instructions are for the updating of software, firmware and channel list to Oyster Digital/Internet systems from 2007 onwards. Please note that not all units included this feature from new and any system purchased between 2007 and Nov 2008 that has not been updated since will have to be returned to us for this to be carried out in order to access the following. Also explained in this sheet is how to configure the Oyster Internet systems to the required Internet mode.Note didnt copy the internet bit!
    Updating software and Channel list
    The Oyster digital system has a procedure built in to assist should there be any updates, changes or additions to the software that you will require to keep your unit in full working order. It will also make changes to the channel list programmed into the system should any channels move, be turned off or new ones added. To access this update procedure please take the following steps.
    1. Turn on the Oyster system and as the dish raises press exit
    2. Press exit a second time to clear all menu’s from the screen
    3. Press the menu button on the remote
    4. Select Main menu from the show list
    5. Select Satellite update from the subsequent list
    The Satellite will now begin to search displaying “Update service, search active” on the TV screen until it locks on to Astra 1 where the update information is stored. Once it has established a lock the software will shut down and you will be taken to the recovery console menu. Again follow these steps to access the update.
    6 Select option 1 to search for updates
    7 Enter the update code 126805200422000
    The system will now search for available updates on the Satellite. When it is done you will be displayed four options.
    Please note: If you enter the code wrong at any point simply press exit to return to the menu and start again.
    8. Select option 1 for firmware update
    The system will now download the current available software to your system. When this is done it will prompt you to press exit. This will then bring you back to the recovery console menu. Please note that if you are already running the current software version the system will tell you and prompt you to press exit again bringing you back to the recovery console menu. You will then need to update the systems channel list.
    9. Select option 1 to search for updates
    10. Enter the Update code 126805200422000
    The system will again search for available updates on the Satellite displaying the four options when it’s done.
    11. Select option 2 for Channel list update
    The system will now download the current available channel list to your system. When this is done it will prompt you to press exit which will then bring you back to the recovery console menu.
    12. Press 9 to boot firmware
    The system will now reboot and a picture will come onto the screen. It should then automatically start a search for your default Satellite but if it does not then please follow these steps.
    1. Press Menu
    2. Select Oyster Digital CI
    3. Select Search Via Location or Internet Service (Whichever is preferred)I used location
    4. Choose current country The system will now begin to search and within a few moments should acquire the requested Satellite and operate as normal and the procedure is complete.
    • Like it Like it x 4
  5. Bluemooner
    Bluemooner Funster Life Member
    Mar 30, 2012
    1,287
    1,721
    Ribble Valley
    I get an email from Maxview when an update is due
  6. dpsuk999
    dpsuk999 Funster
    Jun 6, 2012
    343
    308
    Leeds
    Many thanks
    David
  7. DBK
    DBK Funster
    Jan 9, 2013
    9,199
    12,775
    Plympton, Devon
    If your dish of oysters is spinning I suggest drink less wine with them. :)
    [​IMG]
    • Funny Funny x 1
  8. s20hymer
    s20hymer Funster
    Jun 11, 2011
    276
    332
    Wiltshire
    Thankyou, Mike
  9. walburga
    walburga Funster
    Aug 20, 2007
    309
    107
    Leyland
    My Oyster Vision 2 (up-dated prior to prchasing the motorhome 5 months ago) will not find Astra 2, the dish goes up, spins, alters the elevation, but finds nothing.
    I haven't used the system for 3 weeks prior to this last w/e. Previously Astra 2 has been found with no apparent problems.
    I know it's rained a lot lately, but would that affect the lnb ?
    I'd like to see if I could locate Astra 1, to see if the lnb was ok, but I've not got instructions on how to manipulate the system.
    I found this thread but I'm not sure of some of the terms being used...reference is made to pressing the menu button on the 'remote'...is that the 'operating control device' that is hard wired to the control unit ? This small box has the following icons on it...sat dish, back arrow, forward arrow, and a tick.
    If it's not the same box, then I've not got the remote.
    The Oyster is great when it's working, but if anything goes wrong it's not as easy to fettle as the dish clamped on a pole clamped to the roof access ladders.
    Hope someone can help me.
    regards
    Allen
  10. Smith and Sharp
    Smith and Sharp Funster
    May 31, 2015
    1,805
    2,881
    Cornwall
    I'm resurrecting this thread as I'm having this exact problem and as @walburga describes the same box that I have. I would appreciate any help on this thanks
    Did you get yours sorted walburga...?
  11. walburga
    walburga Funster
    Aug 20, 2007
    309
    107
    Leyland
    Yes..all sorted...I'm sure I posted that all was now working as it should be.
    Anyhow, I'll repeat what I did to sort it :-
    ''a previous poster mentioned Oyster Sat-tech (ten-haft Oyster makers) on 0858 575 928, so I thought give them a go....I spoke to a lovely lady called Margaret, who knew all about the problem...at least 3 of the transponders on astra 2 have changed, she took me through the procedure of changing them whilst I still had the phone in my hand.
    Everything working now as it should.
    Margaret said that 1 of the transponders was still ok, and that the system would've eventually found it after it had gone through the other now redundant ones.
    Brilliant response from Oyster Sat-tech, especially Margaret.''
    This was from late December, it went off tune again mid March...so I again talked to Margaret, she said that the transponder frequencies had changed again, and proceded to talk me through the new values over the phone...only takes a few minutes. All ok once again.
    Hope that helps.
    Allen
  12. Smith and Sharp
    May 31, 2015
    1,805
    2,881
    Cornwall
    Thanks I'll give it a go......:pray:
  13. PP Bear
    PP Bear Funster Life Member
    Apr 5, 2013
    2,478
    7,684
    UK
    Just called Athony Read (http://ten-haaft.com/en/?noredirect=en_GB) who were excellent. Fantastic customer service :)
    I was watching my dish just spin while it tried to lock onto an Astra 2 signal. One quick phone call and 10 mins later, Anthony had me all updated and locked back on with a system update :)
    No mess, no fuss, just a very knowledgeable and patient man who talked me through the entire process :)
    He said he's been inundated since March with phone calls. He thought it might be down to people taking their motorhomes out after a winter stand down :)
    If your struggling, give him a call and see what he can do :)
    Ended up with an email pasted below:
    Good afternoon,
    Please see below for our address details.
    Should you wish to book in to have the system software updated at some point then please contact me on the office number below.
    Kind regards,
    Anthony Read
    Senior Technical Advisor,
    Oyster Sat-Tech LTD
    Unit 5 Hemploe Bus Park
    Hemploe Road
    Welford
    Northants
    NN6 6HF
    Office: 01858575928
    Direct line: 01858570924
    Mobile: 07979745688
    Web: www.ten-haaft.de
    • Useful Useful x 1
