Overweight ! (1 Viewer)
Jul 29, 2007
6,526
39,282
Ipswich
RV and PVC
30 years
Hi its not a requirement to have it weighed, mines done by VOSA and all I get is the emissions print out and the pass certificate.
The only reason they need your weight is for the brake test calibration.
Olley
43,207
48,804
Mine was weighed at the last MOT. If its not a requirement why it i done....... Geoooooooooo
Jim
:Smile:
was it done at a ministry station ?
LGV's over 7500kg probably do need to be weighed at test and as they have the means (weighbridge) they will use it anyway as a matter of coarse as more LGV's will be tested than cars/vans.
just possible they do it for the brake test efficiency % calculations if no other % is available.
bugger....olley got in first !
madbluemad
Banned
Jan 26, 2008
3,327
239
spain
just looking
since 1980
Hi pappa.
I took it to a dealership/garage for Service, MOT and a few other bits that needed doing like a new flooor cos the plumbing had leaked and the floor was rotten.
They in turn took it somewhere else for it to be MOT'D. It was interesting because it weighed less than the factory shipping weight and the transatlantic shipping weight :whatthe:
Jim
:Doh:
Jul 29, 2007
6,526
39,282
Ipswich
RV and PVC
30 years
Hi are you seeing an actual weight certificate from a weighbridge? or are you seeing it on the brake test print out?
madbluemad
Banned
Jan 26, 2008
3,327
239
spain
just looking
since 1980
Its an actual weight certificate from a weighbridge olley. It was appended to the mot certificate along with the emissions print out
Jim
:Smile:
Jul 29, 2007
6,526
39,282
Ipswich
RV and PVC
30 years
Hi Jim when I take mine in, he looks at the plate, then askes me how heavy I think it is, and thats me weighed. :ROFLMAO:
And that's VOSA
Olley
PS I think brother who's a tester for cars told me his brake rollers automatically weigh the car.
43,207
48,804
Hi pappa.
Jim
:Doh:
were the factory and trans shipping weights in pounds or tons ?
if in pounds then someone got it wrong.
american and uk lbs are the same.
if in US tons then it would be lighter.
1 american ton = 2000lbs
1 uk ton = 2240lbs
not sure but i think all shipping is calculated in tons, whether metric,imp or american.
6,526
39,282
Ipswich
RV and PVC
30 years
Hi might also have been "Tonne" this from wiki "The tonne is equal to 1,000 kg or 2,204.62262 lb" ::bigsmile:
Olley
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
they normally dont weigh the trucks dont know of a ministry station in cornwall with a wt bridge . what they do isput a big clamp on the back of the truck and apply pressure instead of weight. unless you have a test weight put in the back . we used to have a big concrete weight that had a wt docket so they knew its wt and could work the braking efficancy from there.
madbluemad
Banned
Jan 26, 2008
3,327
239
spain
just looking
since 1980
get worse dunnit....now we have 3 different tons/tonnes :Doh:
As long as there all legal :winky:
Olley
A tonne is metric and a ton is imperial so theres very little differnce. I must know check my docs when I get home. Not that it will make any difference but Iv'e got to know
Jim
:RollEyes:
Aug 9, 2008
203
7
Lanner - Cornwall
A Class RV
20 + Years
had my MOT at the ministry test station in Camborne, Cornwall in April this year, and to test the brakes they have a weighbridge built into the rolling road so they get the correct brake pressure for the weight of each axle, I actualy followed a 7.5ton delivery lorry through the test site and it was interesting watching a fork lift truck bearing down on the rear section whilst testing the brakes.
Anyhow back to the point in question although the vehicle was weighed, its not an MOT requirement otherwise I would have failed, I have since unloaded a lot of baggage ( she wasn't ammused) to bring it down to 7.4 ton.
The tester did warn me that if he saw me outside on the public road he would be obliged to stop me, so I was duly warned and took heed.
Even though I was over the limit in weight the Brakes performed well within the tolerances.
Brian
