Overheating Problems
Discussion in 'Motorhome Chat' started by OddSocks, Aug 17, 2014.
  1. OddSocks
    OddSocks Read Only Funster
    Apr 10, 2014
    479
    395
    Cornwall
    My old apache (1990 Mercedes 208D) Is having some terrible troubles with the heat here in Portugal. As it gets hotter there is a loud grinding/scraping horrible noise starts coming from somewhere on the drive train. Once it is cooled it runs smooth again. Anyone have any ideas what this might be. We spent hours sitting on the hard shoulders of motorways today as the engine got hotter and hotter climbing hills in the hot sunshine. It was a real struggle today! I have had to climb hills in 3rd gear at half revs as going up any faster or revving any higher has caused it to overheat and the noise is so scary!!!
  2. Ed Excel
    Ed Excel Funster
    Nov 27, 2012
    869
    577
    Ribble Valley
    Could be binding brakes. Have you tried rolling with the engine off and the vehicle out of gear?
  3. tonytange
    tonytange Funster
    May 19, 2013
    22
    17
    Southampton
    Hi check out your cooling fan on engine its a viscous type which only drives when hot it will spin freely when it's cool with a slight drag but smoothly no cluncts , when hot oil in unit will drive fan if it's worn out it will sound like a bag of nails olso fan will usually only work when engine needs it is up hills not on the flat even when the weather is hot
    Hope this is of some help
  4. ivorantony
    ivorantony Funster
    Jan 22, 2013
    507
    537
    London SE
    Could be timing chain or tensioner? If the oil gets too hot the oil pressure will drop and the tensioner moves away from the chain and causes a slapping sound, check oil level and if needed fill up with a heavier grade of oil,
  5. OddSocks
    Apr 10, 2014
    479
    395
    Cornwall
    Thanks guys! :)
    We have been camped up over night and everything is cold again now. I am going to over the van with a fine tooth bomb and see if I can spot anything. Will test the fan and look at the tensioner on the timing chain etc as suggested.
    I'm sure it isn't the breaks as it only happens when we are climbing hills in the hot weather. This is something we are going to have to avoid from now on. We will plan our journeys around weather reports, or drive early mornings or late evening etc only. Portugal won't get any less hilly, and it will only get warmer as we progress south!!!
    Very worrying. Got no sleep at all last night this just playing on my mind!!!! We are soooo far from home and don't speak a word of the language!!!
  6. martin2603
    martin2603 Funster
    Nov 25, 2013
    315
    283
    kent
    HAVE YOU CHECKED THE DIFF OIL?
  7. Barclaybasher
    Barclaybasher Funster
    Apr 13, 2012
    2,455
    7,285
    Derby
    GEARBOX OIL ?
    WHEEL BEARING ?
  8. buckby
    buckby Read Only Funster
    Sep 6, 2013
    213
    148
    nottinghamshire
    Could be propshaft bearing especially with the heat off the roads then when it cools it would be ok worth a look
  9. Leftlegger
    Leftlegger Funster
    Sep 29, 2012
    418
    401
    N.somerset
    too keep it cooler going uphill i would suggest turning on the heater and fan,deflect the warm air where its most comfortable and open the windows?
    • Like Like x 5
  10. tambo
    tambo Read Only Funster
    Jun 21, 2014
    875
    637
    Dunfermline fife scotland
    For peace of mind and to prevent any serious damage it may well be worth your time taking it in to a mechanic and have them give it a check over and a test drive
    There's so many things that could be the problem .....you only have to see how many has been suggested here.
    If you have poor mechanical knowledge and it's worrying you ....that's the best course of action
  11. Barclaybasher
    Apr 13, 2012
    2,455
    7,285
    Derby
    Tambo is right.
    Sounds like a problem that could leave you stranded in the middle of nowhere - I wouldn't travel very far until it's sorted.
    If a bearing has gone it will create heat as well as noise - oils seals will fail or grease in bearings will melt - then it will fail completely
    I would:
    Check for play in water pump, alternator, loose fan belt
    Take off the hub caps to check the wheel bearings - first sign would be melted grease - check the wheel that the tyre failed on in particular
    Get under the van, check rear axle bearings - oil on inside of rear tyres - leaks from axle itself - propshaft - oil from rear of gearbox
    Unlikely - but I would also check exhaust mounts - a loose exhaust - or loose baffles in a silencer - can make some strange noises
    If I could not see any problem I might travel to the nearest town - carefully and seek help from a garage
    I assume you have breakdown cover - ring the them - they would rather help than have to ship you back to the UK
    Make sure you have food, water, gas and your phone charged - if you do get stranded at least it should be manageable
    Keep us updated - if we can help we will - but it is difficult sorting mechanical problems over the internet
    • Like Like x 2
  12. jenny and mitch
    jenny and mitch Funster
    Sep 16, 2010
    1,952
    1,697
    Bungay Suffolk
    Good advice from all above.. But DONT just drive on and hope.. It could be dangerous mate.. The viscous fan sounds a good first thing to check, if it does seize it will "let go" and go through the radiator, so do get these things checked asap at a reasonably good looking garage.... Good luck.. Mitch..
  13. JJ
    JJ Funster
    May 1, 2008
    14,770
    26,384
    Where in Portugal are you?
    JJ :cool:
  14. OddSocks
    Apr 10, 2014
    479
    395
    Cornwall
    Had the diff anf gearbox oil replaced a couple of months ago before we set out. Should be OK, but don't know how to check any of this.
    I thought this too. The 'boot' over the shaft bearing is missing. There are two prop shafts, a short one from the gear box leading to a joint, then a longer one to the rear diff. I think it the join between the two that I suspect! No visual problems there though, no signs of wear or tear.
    Great idea! Hadn't thought of that! Will try it next time we are out.
    Sorry Barclaybasher forgot to quote your post. Thanks - I will check out as many of those things as I can!
    We are in Figueiró dos Vinhos, very central. I am camping at a great little site run by an English couple. Getting lots of help and advice from them. I will have the van booked in to the local mechanics as soon as I can.
    We drove it down to town today and back and had no problems, but it does get hot quick on the hills still. The fan is running normally, it is always on if the engine is running as far as I can tell. It turns smoothly with only a little friction when the engine is cold. Oil and coolant are both fine.
    2 months ago before we left the UK we had a full service and MOT. All oils and liquids. Checked all the breaks and disks out, basically everything we could think of to check before going on a long journey.
    I think it might be either prop shafts or gear box. I can't find a dip stick for the gear box oil though?
    Also - this is not a chain driven engine like some have said. It is the Mercedes 208D with the 601 engine. It has the "poly v-belt" according to the book, and I have checked it out and it looks to be in good order, but I can only see a little bit of it from under the van.
    Thanks everyone! :)
  15. Barclaybasher
    Apr 13, 2012
    2,455
    7,285
    Derby
    Glad you are OK and maybe getting things sorted.
    I don't know your base vehicle but most gearboxes and axles do not have dipsticks, you normally fill through the side until the oil overflows out the same hole.
    Keep us updated (y)(y)
  16. Tootles
    Tootles Funster
    Sep 14, 2013
    9,141
    32,618
    Lancaster
    Viscous fan's suffer badly with age. We had exactly the same thing with a Jeep Cherokee. At your first real opportunity, get the damned thing off and into the nearest skip, and replace with a pair of Kenlowe fans. You get a complete kit, ready to fit for your model. Ring them if you cant see yours. (y)(y)
    http://www.rimmerbros.co.uk/ItemList--Kenlowe--m-4494
    • Like Like x 1
  17. OddSocks
    Apr 10, 2014
    479
    395
    Cornwall
    Thanks Tootles - probly won't be back in the UK for a month or two yet. Will get her into the nearest decent mechanic as soon as I can and get the fan and everything else looked at.
    Will post an update once I have some progress.
  18. Al-Di
    Al-Di Funster
    Mar 15, 2014
    988
    3,806
    prestwich
    theres a good mechanic in Fig, at the garage opposite the internet cafe, he fixed my disco a couple of years back and was cheap,
    are you house hunting by any chance,??
    Alan +Diane
  19. OddSocks
    Apr 10, 2014
    479
    395
    Cornwall
    Hi!
    Yes we are house hunting. Have a lot to look at - currently focusing on the Miranda Do Corvo area. Love it there.
    We have just looked at a couple in Figueiró dos Vinhos but nothing too exciting yet.
    We will be in the Miranda Do Corvo aire in a few days time for a few days while the agent drives us around the properties we have shortlisted! :)
    By Fig do you mean Figueiró dos Vinhos lol? I saw a garage there when we drove though yesterday. Not sure where the internet cafe is though? It is on a cross roads as you drive in to town???
  20. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    one thing to look out for is heat, a dodgy bearing will get hot, you say a shoud is missing from a prop shaft, well the grease will be missing as well to me it seems the obvious place to start. Heater/blower on full blast will help cool the engine, make sure rad is not blocked maybe fit a larger one or additional fan. wheels will get hot if a brake is binding or bearing shot, a quick touch to prevent getting burnt will maybe find it. oil seals on a vehicle of that age are prone to fail especially if it has just sat around most of its life. Double check fluid levels every day.
    Was the brake fluid completely changed or just topped up. It does not last forever, rubber hoses to the brakes fail on the inside where you cannot see and cause brakes to bind, again the wheel hub will get hot. Good luck with the house hunting and I hope you get the bus sorted soon. Whatever happens don't just plod on. Park up until it's sorted. Good luck mate.
