Overheated leisure battery (1 Viewer)
ukbill
5,501
5,274
Pinoso
4 berth low profile
starting on saturday 10/3/2012
sounds like the battery has gone but i aint defo on that normally a heated battery is a duff battery
Jaws
23,836
72,474
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Hi guys..
I would check to make sure they are really leisure batteries and not standard ones that are vented.
If the later the chances are one has run out of acid/water which might well mean the other is not far behind.
Once they have boiled there is only one solution.. replacement :Sad:
Do you have a multi meter to hand ?
I would check the voltage of the 2nd battery whilst on hook up as it may also be the on board charger has thrown a wobbly .. Max voltage should be no more than 14.8 v ( more usually I would expect 14.2v max. )
scotjimland
2,324
10,045
A Woosh bang
you did the right thing.. a hot gassing battery gives off explosive gas.. if possible switch off the charger so you can still use the EHU..
as said.. duff battery ,, but if both are overheating have you checked the electrolyte levels.. ?
if that is ok, the charger could be over charging ..
if not sure how to test the charger output, have it checked by an auto or motorhome electrician ...
edit .. jaws beat me to it..
MikeandCarolyn
2,170
1,468
Worle,North Somerset
Since 2009
One of our 2 leisure batteries has overheated whilst we are on ehu in france we have disconnected the ehu any advice on what we should do would be very helpful
Gail and Karen
I would find nearest Camping car dealer or service agent and see what they say.
If you're on a campsite,Reception should be able point you in right direction.
If not,Google.fr is your friend ::bigsmile:
Mike
MikeandCarolyn
2,170
1,468
Since 2009
Gail and Karen
Out of interest,where are you ? We are at Balma,Toulouse.
Mike
Spottycatz
452
487
Racodorm
Coachbuilt Low Profile
Still making mistakes! But they're not as costly.
The same thing happened to us in Spain earlier this year. Be aware that your second battery may now be looking to do the same thing. :whatthe: Our second battery died a week after the first. A VERY expensive occurrence. :cry:
gailsunnymeed
Sep 29, 2012
83
463
Wakefield
Low profile
Many thanks for all your advice, techno has sorted us out via text until we get home.
Mike we are in the The loire Valley staying on the campsite at Les Portes de Sancerre and moving on tomorrow to visit friends in Brittany
Gail and Karen
scotjimland
2,324
10,045
A Woosh bang
Many thanks for all your advice,[HI] techno has sorted us out via text until we get home. [/HI]
Gail and Karen
don't keep it a secret .. what advice have you followed ?
gailsunnymeed
Sep 29, 2012
83
463
Wakefield
Low profile
Just what you said he told us how to turn off the main charger which he thinks is over charging, he wanted to know what the solar output was and said we should be okay to get home and then hopefully techno will sort it out for us once home
Many thanks Gail and Karen
