Over head bed in A class Rapido
Discussion in 'Tech/Mech General' started by weekenders, Apr 2, 2016.
  1. weekenders
    weekenders Funster Life Member
    Apr 30, 2008
    2,186
    1,240
    Leicestershire
    we have had our Rapido nearly 3 years and never used the over head bed, it has been lowered a couple of times no problem, but recently when trying to push it back up and lock it in place it is very heavy and takes 2 of us to push up back into place.
    Any ideas why this may be? Something to do with the bracket not used much? Does it need greasing?
    If anyone has had same problem, how did you fix yours
  2. Smith and Sharp
    Smith and Sharp Funster
    May 31, 2015
    1,446
    2,418
    Cornwall
    • Informative Informative x 1
  3. f6c
    f6c Funster
    Nov 7, 2010
    3,231
    866
    gloucestershire
    Out of Gas:whistle:
  4. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,018
    6,041
    West Sussex
    Sounds like a strut problem to me should go up with fingertip pressure.
    Worth pointing out with A class van in cold weather if using the heating you should lower the bed a few inches to allow air to circulate or you can get condensation of the roof above the bed.
    • Informative Informative x 3
    • Like Like x 2
    • Useful Useful x 1
  5. Polar bear
    Polar bear Funster
    Nov 13, 2012
    199
    128
    Somerset
    Check gas struts have been installed correct way round as can fail Iff upside down.
  6. weekenders
    Apr 30, 2008
    2,186
    1,240
    Leicestershire
    Has anyone had new struts fitted by a motorhome dealer repairer, price quoted for fitting only, or has anyone fitted new struts to their motorhome (ours is a Rapido)
  7. Armytwowheels
    Armytwowheels Funster Life Member
    Aug 10, 2012
    4,095
    6,655
    Spain for the winter
    Hi both. I believe @Jim had to replace the bed struts on his previous van. Also I think @JJ did his. Both Hymers but cannot imagine they would be that different.
    • Like Like x 1
  8. Forestboy
    Forestboy Funster Life Member
    Jul 31, 2007
    5,076
    8,156
    Forest of Dean
    I fitted a pair last year on my Hymer front bed.
    Easy enough job don't need a dealer simple enough diy job.
    Will skin your knuckles though.:)
  9. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    2,954
    2,749
    Englishman in Mid Wales
    Can't get it up eh? See it really is true, use it or lose it;)
    • Funny Funny x 4
  10. weekenders
    Apr 30, 2008
    2,186
    1,240
    Leicestershire
    Does anyone know any dealers/workshop who would fit new gas struts to our Rapido, I have tried Edgehill today and they have only put some on Hymers.
    any advise would be appreciated.
    ps we are going to Peterborough show
  11. Mel
    Mel Funster
    Oct 6, 2012
    2,103
    2,114
    De Haan Belgium
    I have now sold our Rapido.
    So cant check but are there gas struts on a rapido?
    I thought it was a sring ballance system.
  12. cranky
    cranky Funster
    Oct 29, 2012
    401
    461
    essex
    Mine has gas struts but before you change them, make sure you don't have too much bedding on it. I have to spread pillows and quilt out or it won't go all the way up. If it lifts easily to start with and gets harder as it gets near the top it may be all it is.
    As an aside, I have never had a condensation problem and never lower the bed unless it is going to be slept in.
  13. weekenders
    Apr 30, 2008
    2,186
    1,240
    Leicestershire
    Yes @Mel they are gas strut, hubby tried taking one off and nearly took his head off!!!!
    • Thanks Thanks x 1
  14. weekenders
    Apr 30, 2008
    2,186
    1,240
    Leicestershire
    @cranky we don't use it to sleep on, as we have a fixed bed in the rear, I keep a blanket on it for when sitting outside in the cold.
    but it is very hard to push back up on the lock position, it takes 2 of us, and we have been told it should just push up quite easy.
    we also don't have any condensation as we always leave a heater on when really cold and not in use on our drive.
  15. Speve
    Speve Funster
    Jul 29, 2013
    2,090
    1,826
    Salisbury
    Thanks @Lenny HB We learned that to our cost and the duvet got all black spots on it the missus wasn't to pleased.
    • Like Like x 1
  16. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,018
    6,041
    West Sussex
    You don't know until you pull the bed down when the heating has been on. A particularly cold night the Christmas before last I had put the heating on full blast when we went back to the van about 3 hours later I dropped the bed and there was condensation on the roof above the bed. I asked dealer about it, they said quite common in A class vans and advise dropping the bed a couple of inches when running the heating hot to allow air to circulate.
    I only ever do it if it's really cold and the heating is on a long time.
  17. Speve
    Speve Funster
    Jul 29, 2013
    2,090
    1,826
    Salisbury
    @Lenny HB yes I don't have heating on much but always make sure there's a gap at the top haven't had a problem since except banging my head on the bed end ouch!
  18. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,018
    6,041
    West Sussex
    Know the feeling, got spare clothes stored in ours at the moment so it's a couple of inches lower.:)
    • Like Like x 1
  19. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,018
    6,041
    West Sussex
    Bl**dy slow wifi
  20. iandsm
    iandsm Funster
    Jan 3, 2008
    1,624
    2,767
    Suffolk
    Funny you should say that. We were away in march and it was bloody cold, we had the hosting on four or five hours each night and on the last night I pulled down the bed to find that one of the pillows was quite damp. I assumed the worst and very closely inspected everything when we got home and tested with high pressure water, no leaks at all.
    The mystery leak is solved, I recon it must have been condensation. Never experienced it before but then never and the hating on for o long in such cold temperatures before.
