oven wont stay in (1 Viewer)
Nov 18, 2011
11,862
42,770
Planet Earth
A van
Over 25 year's
hi all my oven won't stay in it works fine for maybe Min then you see the flame lift and it goes out been working fine a few week ago all was OK at las hab check :RollEyes: it started giving us problems at chester meet:Sad:
thank's bill
JayDee
1,057
169
N. Devon
7 Years after 5 years with caravan.
Could be the sensor has packed up (the thing that, if it doesn't detect heat, cuts the gas to the burner).
Just a guess mind.
John
peter marshall
2,466
1,704
Cleveleys,Lancashire
Low Line
9 Years
Hi Bill
I had a prob once with the hob not lighting, it turned out we had not put the glass top right back so it was showing a blockage and was not igniting properly, just a thought. Pete
Jan 28, 2008
10,111
18,364
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
check air supply burners normally lift when searching for oxeygen run it with the door open see what happens keep van well ventilated when you try this
656
1,052
290
The universe
Sounds like the Thermocouple has failed. Look here
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
is it just the oven or is it all gas appliances ????
if you light a couple of rings instead of just 1 then it could lead to the regulator restricting gas flow as it is something that is often overlooked.
Wildbill
Nov 18, 2011
11,862
42,770
Planet Earth
A van
Over 25 year's
thanks Andy it isn't that it wont work by it's shelf with just oven on:Eeek:
