outside socket ?
Discussion in 'Motorhome Chat' started by beachcaster, Dec 29, 2013.
  1. beachcaster
    beachcaster Read Only Funster
    Dec 18, 2010
    3,048
    3,171
    east sussex
    I want to run an outside socket......... somewhere on the outside of the van
    to plug in SWMBO's new electric bike charger when we are away....would also be generally useful.:Smile:
    We mainly stay on sites with EHU........So perhaps a spur from the existing 13 amp mains to perhaps underneath the motorhome...perhaps switchable
    and waterproof............any thoughts before I get it sorted.
    my next door neighbour is a qualified electrician and he will do it for me .but I prefer to go to him with some properly thought out ideas and suggestions for gear.
    barry
  2. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,274
    7,935
    West Norfolk
    There's bound to be something in the NCC standards about doing that. It probably involves extra ventilation holes and having it switch off if you start the engine!:BigGrin:
    It might well be worth waiting for a sensible reply from one of our traders!:thumb:
  3. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,185
    14,958
    Leeds the one up North
  4. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,262
    5,245
    East Sussex 01-580-881288
    http://www.johnscross.co.uk/bullfinch-electric-outlet-point.html
    How to do it !
    Bullfinch Electric Outlet Point
    Bullfinch Electrical outlet point for Caravans and Motorhomes, bring power out of your van with this electrical outlet socket.
    Ideal for:
    • power tools
    • electrical appliances up to 13 amp rating
    • lighting
    • TVs and other leisure products
    Note the following features:
    • IP55 protection against water & dirt ingress when plug inserted & lid closed
    • innovative, attractive design
    • high quality for a long reliable life
    • compact
    • lightweight
    • easy to fit - requires 105mm cutter and 4 self tapping screws; easy to attach inlet cable
    • well styled
    • further versions available for plugs for other countries (eg European, USA, Australia)
    • also available - same housing but fitted with 12volt (Cigar lighter fitting)) / Satellite / TV connections - ideal for touring caravans , motorhomes, etc.
    You will require a 105mm cutter to create the orifice.
    It is also supplied with 4 fixing screws.
    General information
    • External 220/240V 13A electric socket for mains electric accessories including TV’s, computers, games consoles power tools, mowers etc (dependent on power rating of appliance).
    • Recessed socket allows cover to be closed over inserted plug.
    • IP55 waterproof protection - Weatherproof (to the requirements of IP 55 dust and water ingress) with cover closed and plug fitted.
    • Robust and durable – manufactured from high quality materials.
    • Easily installed using a core drill.
    • Well designed and compact.
    • Cover has positive latching in open and closed position.
    • Can accommodate most standard 13A plugs whilst maintaining seal.
    • Low profile installation.
    • Simple installation procedure, cut a Ø105 mm hole with a core drill and affix with self tapping or similar screws
    Bullfinch Electric Outlet Point Technical information: for 13 A Electric Outlet Point (Socket)
    • 250V ac rating
    • Standard UK 13A 3 pin socket (other socket versions available eg. U.S, Europe, etc.)
    • Electric components to BS 1363 where applicable
    • Plastic parts made of high quality materials with long-term UV resistance
    • Total sealing between device and wall of prefabricated structure
    • Total sealing between cover and body even with plug fiteed
    • Dimensions – 125 x 140 x 58 (deep) mm
    • Weight – 242 gms
    • Main body and Cover: - Polycarbonate 30% reinforced with glass fibre
    • Hinge pin and screws: - stainless steel
    • Seals: - UV and ozone resistant silicone rubber
    • Wall gasket: - UV and ozone resistant EPDM
    [​IMG]
  5. JockandRita
    JockandRita Funster Life Member
    Aug 2, 2007
    5,797
    7,565
    Lincs/Cambs border
    Hi Barry,
    Because I didn't want to drill a hole in the side of the MH bodywork, I bought >>one of these<< from CAK Tanks. I just swapped the ends round, so that the 3 pin socket didn't damage the MH bodywork. It gives me an external socket if I need one, when plugged into EHU. When the awning isn't wound out, I find another method of keeping it dry. :Wink:
    Cheers,
    Jock.
    • Like Like x 3
  6. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,755
    3,254
    Eastbourne East Sussex
    The only time we need this is that if its hot SWMBO likes to do ironing outside (I know, I've told her ironing is unnecessary but she doesn't listen)
    For this we just chuck an extension lead out of the window, plugged into the socket for the microwave which we removed.
    • Like Like x 1
  7. cmcardle75
    cmcardle75 Read Only Funster
    Jun 8, 2012
    670
    263
    Reading
    Basically, you just need an IP rated socket. There are loads out there with different characteristics. There will be differences in such things as:
    Price
    Double vs Single
    Switched/Unswitched
    IP rating level (minimum 66 for this application)
    Is IP protection maintained when in use?
    Physical size
    Colour
    Only you will know what is important to you. However, my choice was:
    http://www.screwfix.com/p/bg-nexus-13a-1g-switch-socket/35096
    Screwfix also do:
    http://www.screwfix.com/p/lap-13a-1-gang-dp-switched-plug-socket/30430
    http://www.screwfix.com/p/mk-masterseal-plus-13a-1-gang-switched-socket/30703
    All available in doubles also.
    As it is a vehicle, I'd connect using arctic flex, rather than 2+E solid cable.
    • Like Like x 1
  8. cmcardle75
    Jun 8, 2012
    670
    263
    Reading
    I should mention that the Bullfinch one might be expensive, but it has the advantage of flush mounting if you want it mounted to the side, rather than underneath out of sight.
  9. hilldweller
    Dec 5, 2008
    26,897
    25,746
    Macclesfield
    Better to have the 240V lump safe and dry inside and extend the nice safe 24V wires.
  10. FULL TIMER
    FULL TIMER Read Only Funster
    May 31, 2012
    796
    712
    NORWICH
    That's the set up I have mounted on the front of the box body between cab and box and as you say flex should be used on all vehicles as I understand it rather than solid twin & earth.
  11. PaulyP
    PaulyP Funster
    Jul 29, 2011
    1,810
    3,043
    Manchester
    Mine came with an outside socket already fitted underneath.
    Very useful but a bit awkward to reach, have to get down and reach under, thinking of moving it so it is a locker space which would be more accessable.
    It looks as if it has been spurred of the ring main.
  12. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,705
    17,323
    YO11 2BD
    just fit a bog standard 2 gang domestic socket and plastic backbox in an outside locker.
    the charger wires are thin enough to pass between the door seals without damage to either.
  13. jollyrodger
    jollyrodger Funster Life Member
    Oct 1, 2012
    3,557
    7,064
    Plymouth
    You may also try Coastline Campers they also do loads of flush fitted sockets for around £16 similar to those already mentioned
    :BigGrin:
  14. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,365
    9,811
    or the good old fashioned version of the outside socket....been about for years and much cheaper at £12.50
    [ame="http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=221330848911&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en"]White External 13 amp Socket Box Caravan Motorhome campervan PO119w | eBay[/ame]
    [ame="http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=221330848911"]White External 13 amp Socket Box Caravan Motorhome campervan PO119w | eBay[/ame]
    whats up with posting links tonight, the forum software keeps converting to an internal link
    item number 221330848911
  15. maxsdad
    maxsdad Funster
    Oct 5, 2009
    298
    234
    anglesey
    Removed the fridge lower external grill and fitted an external weather proof socket from b&q into the fridge 240v supply mounted in the space behind the fridge
    This cable also supplies one of the internal sockets so should have adequate supply.
    Bit of a faff having to remove the grill to use but its only occasional use and its underneath the awning.
    Considered cutting a small groove in the bottom of the vent so it can be replace when plugged in, but not had the bottle to do it yet might look a mess
  16. Techno
    Jul 28, 2010
    14,185
    14,958
