Outside light cover removal ???
Discussion in 'Tech/Mech General' started by Jaws, Apr 11, 2015.
  1. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,690
    23,090
    Narrfoook
    Sorting out daughters new to her 1990 Frankia and making good progress.. But have a weird one
    The outside light ... How to remove the cover !
    It is the type fitted to a lot of vans ( about 9" long, all white, with a sensor at the bottom )
    It is simialr to this one:
    [​IMG]
    But as well as the ball type sensor has what looks like another sensor just above the ball ..
    I do not want to force anything !!
    Anyone know how the cover comes off ? The bulb is a tad unwell !!!
  2. vectian
    vectian Funster
    Sep 21, 2013
    152
    132
    Isle of Wight
    You get about 2 dozen of your friends around and you all stand around the van and all hold your arms up in praise to the light then rub it first with the left hand then the right hand.
    After all many hands make light work
    • Like it Like it x 4
  3. Old Soldier
    Old Soldier
    Apr 10, 2010
    902
    1,483
    Wells in Somerset
    Similar to mine. Squeeze it together, top and bottom and it should come away from back mounting base plate.
    • Like it Like it x 1
  4. keith
    keith Funster
    Aug 25, 2007
    3,286
    1,672
    Ecclefechan
    They only clip on John. Just squeeze the top down a bit then you slid the cover off the square bit where the sensor is, if that makes sense. Your only problem could be if it's an old one watch out for brittle plastic.
  5. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,489
    6,481
    West Sussex
    I would be inclined to warm it up first, lost count of how many plastic bits I broken trying to get apart after UV has been at them.
  6. Jaws
    Sep 26, 2008
    18,690
    23,090
    Narrfoook
    I do not think it is that old to be honest.. The plastic is still quite supple :)
    Thanks for the info guys.. off to put it in to practice !
  7. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,617
    5,689
    Yr Wyddgrug
    Mine is the same as that John, as others have said gently squeeze top to bottom and extract.
