out or in? (1 Viewer)
lee52
327
119
tyne and wear
selfbuild
newbie
well the rebuild stage has started and I have a heating question my bus came with a eberspacher 5kw derv heater and it works. the question is if I was to run the blow air piping under the bus then having it pop up thro the floor at the relevant points that i need will I suffer to much heat loss with the pipes been in the outside world, I know the proper way is inside the bus but am tryin to have a open plan and dont want to have big ole "skirting boards" to hide the pipe work inside the bus
Dec 28, 2011
2,426
2,769
Stokesley, North Yorks
JoaCamp75Q by Pilote
Still learning since 2010
Inside or you are wasting time and money in my opinion.
The only way you could do it would be with loads of lagging, and even then I don't think it would be as efficient as inside.
Also, if it was outside it would be at risk from water, stones, salt etc. so if it was me I would go for inside.
Only my opinion and I am sure others will have different answers and solutions.
L
lee52
327
119
tyne and wear
selfbuild
newbie
thats what i thought just hoping it would be doable I know the blow air piping is "Insulated" but doubt anywhere to the degree that I,ll need
L
lee52
327
119
tyne and wear
selfbuild
newbie
A very good question.
The air is travelling at a fair old lick in the pipe so does not have that much time to cool.
So maybe less loss than you think.
mmm time for some testing i think. I have a load of pipe coming in the post its the proper truma insulated stuff if you know what i mean, think I,ll run the whole length outside and measure the input and output temps of the pipe and see what i get. if i can get away with it, it will make a much cleaner install
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
Ours runs inside the van and has some useful advantages.
The runs do get hot as they don't have any substantial insulation but that can be a blessing because where they run will also get warm.
As ours pass under the lounge seat the cavity gets warm and as the water tank is under the seat it will never freeze.
The pipe also runs under the bathroom floor (there is a double floor to accommodate it) so this also makes sure the water pipes are frost free.
It then goes via the locker into the bedroom so even the locker gets a warm glow.
As you will see, if it can be done in a similar way, you can gain extra benefits from the warm pipes.
By running outside you will waste all that useful heat, maybe the following vehicle will benefit from your generosity.
L
lee52
327
119
tyne and wear
selfbuild
newbie
I like that lol
suppose it will help to keep all those hiden corners warm and dry. just with doing a full refurb i have a million different options lol I settled on a layout plan but now i have stripped it back to bare shell things change again lol
Terry
11,926
9,033
Lincolnshire
Can't remember ;)
Inside every time or you will need it boxing in and lagging stuffed in the box, you will be surprised how much colder the farest away outlet is compared to the nearest
Terry
Chris
21,044
277,961
None
10 years
Sorry - I thought this was a Yosser thread.::bigsmile:
