Debs
Lovely - sort of reminds me of the little hymer exsis which we had a chance to buy & just didn't appreciate it at the time
Also an Adria Twin 500 at 4963mm:I'm assuming the camper will actually be a 5.5m one as I wasn't aware the 5.0m one was available with a high top ... or is it?
No to a microwave in my opnion. External gas point can be handy in the winter to back feed Gas if you can't get off site due to snow and want an external cylinder. I wouldn't have it for cooking though.Q - should I replace the oven with a microwave or with drawers???
What about an external gas point - I'm thinking on the lines of keeping cooking smells out of the tiny van - I suppose that would mean taking an extra bit of kit for cooking on too.
I have a 2 ring hob inside the van and one of the single ring portable jobbies for use outside. When I am on hookup I don't cook meat (bacon, chops etc) on the hob as it spits all over the van and stinks the van up. For that I have a George foreman Grill. When off hookup I cook it outside. I am relatively happy with this set up however there are occasions when I would love to have had an oven for a pizza, or to keep part of the meal warm while cooking the rest.COOKING: I've decided against the oven - never used the one in the bigger van - I'll have 2 gas burners and I have a double skillet. I have a mini-induction hob (with 1 suitable saucepan & 1 suitable fryingpan - these can also be used on gas) for any time I'm on EHU.
Q - are they much used? - what's the smallest 'accessory' I could get, to use outside? (I guess I only need a single ring.)
FRIDGE: 50 litre fridge/freezer
WATER: I'm seriously considering having a NaturePure system fitted - this will save on carrying an extra jerrycan in places where the water might be a bit iffy. I know a lot of people will drink whatever comes and I have in the past, but I fear water quality is deteriorating in many areas.
If I were starting from scratch I would be aiming for 200AH of battery and 200Watts of Solar as a minimum for fulltiming and spending a lot of time off hookup. Especially if you are spending any time in the UK. The extra battery will allow you to do more than a long weekend and cover you for times when we get no sun for a number of days.ENERGY: 100 Ahr leisure battery. I've ordered the converter's 'standard' solar panel which is 80W.
Forget EFOY unless you are rich.Q - do you think this will be enough? There's the option of a 2nd leisure battery but this would take quite a bit of valuable storage space. There's also be mention of a possible EFOY - I don't know what this is - any help here please?
AWNING: I'm thinking this would be little used especially when I'm on my own. So rather than have the canopy, get some sort of a driveaway/ pop-up tent/ gazebo once I've been out a few times & know what sort of use I'd make of it.
I don't have any reversing camera and never have. I was taught how to use my mirrors and how to reverse on an HGV training course. That is worth a lot more than the mirrors in my opinion. The rear view camera is not that important. The only camera I would sometimes like is a blind spot one for when you are turning out of a junction that is not at 90°. For most of these you can position your van so you can see. However there are a couple over the years where I have had to just creep out and hope for the best..CAMERA: comes with a factory-fitted reversing camera.
Q - thoughts on replacing it with a dual reversing + rear-view camera please?
CAB BLINDS: I'll need something internal - if I'm off-grid I won't want outside blinds.
Q - remis and/or internal thermal?
Check your payload. Other than that no cons. I have been persuaded of the benefits of a trailer by @Jim and hoping to get one this year once I have passed my +E test.TOW BAR: thinking possibility of then taking more 'stuff' & maybe a larger tent when there's more than just me travelling. Won't be often & won't be for v long tours (absolute max 2 weeks)
Q - pros & cons?
Great idea - I have one of these Nokia 105's and they are great.It is worth getting a cheap £20 feature phone and keeping it charged up but switched off. You might drop your smart phone, it might break etc etc. If you live in a house this is not a serious issue but when fulltiming it is probably quite important to have a backup phone.
This is the one I use. The battery in this will last a month if not used.
I wanted to go to Scout's do but won't get the van in timeWhere are you going for your first trip?
I do need a new laptop, this one's on its last legs; I do read loads; I don't really need much computing power, just emails, Fun, a bit of browsing, some writing. 2 USB ports enough, or would you think 4?When considering power it is as important to consider usage as it is to consider storage and generation capacity.
Not on this thread, no. I'm trying to avoid jinxing the build. But I think you know what it isBTW - did you say what you were getting?
Don't understand the following: inverter, Sterling B2B, battery master. (Told you, I know nowt!)
D'you know what: I understood ALL of that aren't you clever Grommett Thank youIf you don't use any software other than a web browser then a Chromebook would probably be an ideal solution for you. They are extremely secure in comparison to all other OS's. There are limitations such as not being able to run windows software. They are very low power usage and the Battery lasts a lot longer than in a standard laptop.
Using an Ebook for reading, and a tablet for watching TV (Netflix/Amazon etc) and you can cut your power usage by quite a bit.
Inverters convert 12v DC to 240V AC. This allows you to use normal mains equipment. However their efficiency leaves a lot to be desired. So for instance rather than using an invertor to power your laptop charger you use a direct DC/DC convertor. For instance my laptop uses 19VDC. If I was to use an inverter I would be converting 12V DC to 240V AC then back to 19V DC. Each conversion process takes power and a loss through inefficiency. It is far better to get a high performance DC/DC converter that will convert 12V DC directly to 19V DC.
Sterling B2B is a battery to battery charger. In most motorhomes something called a split charge relay is used. This lets a small amount of current from the van battery flow to the leisure batteries. This is not an active part so the charge reaching the habitation batteries will always be lower than the van battery. A B2B is an actual active charger. It will persuade the alternator that the batteries are low and the alternator will then produce full output. This is then fed to a proper multi-stage charger which means you get a full and proper charge into your hab battery when the engine is running. I have a 50Amp B2B (currently broken) which was a life saver when taking long trips.
A battery master basically trickle charges the van battery from the hab battery if the hab battery is over a certain voltage. It is more important to have a full cab battery when travelling so you can get it started in the morning Used in combination they give you the best of both worlds especially if you have solar panels as well.
... but you can put a flexible solar panel on a roof box.If weight or space is an issue, an extra solar panel is much lighter than an extra battery, and doesn't take up any useful space (unless you are planning on a roofbox)
