One for you electrical geniuses... (1 Viewer)
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
I need a changeover switch.
I have just fitted frost heaters to my fresh and waste tanks. At the moment, they are wired up to the Sargent EC500 control panel, which means power is interrupted when I start the engine and drive. I want to be able to switch over to a different power source for travelling, if I need to.
So, I need a changeover switch. At the moment I have a separate pos and neg feed to both heaters from the panel, I would like to be able to change this to a pos and neg feed to both heaters directly off the leisure battery.
What sort of switch will do this?
Allan
43,329
49,444
neg wire is not an issue....unless the control panel isolates both pos and neg.
A suitable relay with both normally open and normally closed poles will do.
Engine Battery wire to n/o pole and panel to n/c pole....a wire from common to both heater plates.
Just needs a wire from the ign switch to the trigger terminal on the relay.
Start the engine and the relay will automatically disconnect from control panel/leisure battery and connect to the engine battery.
Allanm
Allanm
5,431
9,192
Since 1987
Both + and - go back to the control panel. I'm not bothered about automatic changeover with an ign wire and relay, sometimes I won't want them to be on when we are travelling A three position switch, one end connects to control panel, centre all off, other end connects to battery.
Something like this
Broken Link Removed
Assuming the heater is connected to the centre terminals and alternate power at either end.
Does that look like it would work?
Obviously I would need two switches.
Allan
RandallC
1,242
3,487
Devizes
A Class Rapido 8096
2012, prior too, 17 years Folding Camper & Caravan
Hi if you consider the photo below and change things around a bit. That is consider the lamps as the 2 power sources, (Sargent & vehicle) and then the battery as the frost heaters. Hopefully you see what I mean. If not let me know. Also don't forget to fit fuses.
(So that's how you get pictures in posts)
43,329
49,444
Something like this
Broken Link Removed
Allan
identical setup to the relay...only manually operated and no need for twin switches unless you want to select just one heater rather than both together.
Problem is it could be left on the engine battery by accident
Allanm
Allanm
5,431
9,192
Since 1987
Problem is it could be left on the engine battery by accident[/B]
Thats a point, I'm bound to leave it turned on and come back with no power left. Maybe your relay idea would be best.
Allan
May 29, 2013
2,597
19,230
Tyneside
Chausson best of Flash 10
Several years now
If you go with either the relay or the switch idea, make sure that they can carry the amps that your tank heaters require. Relay blades have been known to weld together if not rated correctly for the load.
43,329
49,444
the relay setup would be the same amount of wiring as the switch version with the addition of one ign switched wire to trigger the relay.
a 20a relay is a couple of quid...possible less than a suitable switch
Broken Link Removed
TheBig1
17,630
43,277
go with the standard relay option but add a switch to the ign positive feed for the relay coil so you can choose not to heat already warm tanks etc
cost about £5 plus cables
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
If the combined current of the tank heaters is only 5amps, why not simply connect them to a relay, switched by the PSU's 12 volt fridge output?
