On site and no heating/hot water - no lights on panel? (2 Viewers)
Apr 25, 2010
120
38
Durham
LP Coachbuilt
Since 2011
Hi, just set up on pitch, followed usual procedure but the heating/hot water switches (truma combi) will not illuminate. There are no fuses in the main Sargent E450 unit allocated to the heating according to the booklet. I've checked the fuses for Auxillary Supplies, electronics and ignitions but all are ok. Other fuses have an allocated name to them. Is there another fuse somewhere? Any help appreciated, could be a cold night lol. Bessacarr E560, 2011
Apr 10, 2010
552
544
Bedfordshire
Carthago
Since Sept 2003
There are fuses on the boiler itself, including a mains fuse, under the plastic cover.
Apr 10, 2010
552
544
Bedfordshire
Carthago
Since Sept 2003
And, IIRC, there's one down the side of the boiler 'tank'. If the boiler is only viewable from the top, you'll need a mirror to see it.
RandallC
1,242
3,487
Devizes
A Class Rapido 8096
2012, prior too, 17 years Folding Camper & Caravan
Stupid question have you turned the power on via the remote panel. One with lights pump etc on. Sorry I've done exactly this having plugged in checked the fridge is on and then tried to turn on the hot water, penny dropped after a couple mins having made sure the power was on etc.
camel
Apr 25, 2010
120
38
Durham
LP Coachbuilt
Since 2011
Hi, Wingman we are on electric hook up.
Serendipitous- panel power is on
Cavs - will check for these further fuses
Thank you
DanielFord
3,020
3,086
This might also be a silly question, are you sure you have 'juice' coming in from the hookup? Had one recently that you had to twist the plug to switch on the supply.
Apr 10, 2010
552
544
Bedfordshire
Carthago
Since Sept 2003
Camel,
These might be of some use - downloads of manuals here. Link Removed
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
I have instruction for Combi 6 Loaded which shows a 10amp (slow Blow) glass fuse under a cover on the casing?
Pete
RandallC
1,242
3,487
Devizes
A Class Rapido 8096
If poking about under the covers ( no pun intended) don't forget to switch off the mains!
michpiggy
120
108
West lancashire
Elddis advante 285
2 and 1/2 years of owning a motorhome.... 12 years owning a touring caravan
Yes Tom that sounds the same thing
For some reason and we still don't know why our heating will only turn on once the light master switch has been turned on
Even if we dont need the lights on the main light switch has to be on for our heater and hot water to work
RandallC
1,242
3,487
Devizes
A Class Rapido 8096
Regardless of mains hook up or not the system should run on 12Vdc for off grid operation. So should be looking for 12V supply for the heater controls & fan/blower.
Apr 26, 2014
622
606
Thornton Cleveleys
2004 Bessacarr E735
3 years
Is your light master switch turned on ?
Andy and Michelle had same thing at Lincoln and that's all it was.
Mother Ship
440
991
Jersey
Pilote 626D
Since 1986
This happened to us - sounds like same fault we had. We could make it work by unplugging control cable from the control knobs, leaving it a few minutes by which time a click should be heard from the boiler, at that point reconnect the cable. Hope this helps. Our permanent fix was a replacement circuit board on boiler.
Apr 29, 2009
1,203
740
West Sussex
Burstner Nexxo T740
since 2008
Does yours have the marvelleous timer control which has to be overidden manually (bottom left switch on our panel) to allow heating/water to work. (I am assuming that no lights on panel doesnt mean the panel is turned off)
Mother Ship
440
991
Jersey
Pilote 626D
Since 1986
No it did not have any timer control, just the 2 knobs to control settings, when had problem no lights showed up on any setting/position of dials. We had to take fascia around panel off and disconnect cable from back, wait a few mins and reconnect to get it to work. When we got to somewhere to replace circuit board we took the opportunity to upgrade the circuit board to have the digital controller enabling us to have timed heater coming on by itself. So pleased with it now, so easy to set whatever choice of setting, more user friendly and luxury of waking up on frosty mornings to timed heating!
peter marshall
2,466
1,704
Cleveleys,Lancashire
Low Line
9 Years
Like Cavs said the fuse under the top cover, mine just needed taking out and putting back in it then worked ok there after. Pete
camel
Apr 25, 2010
120
38
Durham
LP Coachbuilt
Since 2011
Hi, just an update. Managed to get our MH into the garage today and all been checked. Conclusion is a faulty circuit board, luckily they got one today, £235 fitted . Hopefully that's solved the problem and it's off to Chatsworth for the Christmas market next weekend.
Thanks to everyone who offered some great advice as usual
Paul
tonka
10,829
21,524
Cannock, Staffs
A class Burstner 800
Since 2000
Autotrails usually have seperate fused/switched boxes in the van away from the Sargent unit.. Mine has one in the cupboard below the TV in rear lounge.. You may have one hidden somewhere, common to get knocked off or fuse could go in that spur.
Worth noting for others maybe.
