- Aug 18, 2014
- 23,740
- 133,196
- Transit PVC
- 16 years since restarting
On my Mh it was originally built with an on board gas tank. There is no way using refillable cylinders externally as there are no lockers & nowhere to even install one. A previous owner obviously finding out that in Spain LPG filling stations are few & far between & certainly so back in 1990 when this was constructed , disconnected the tank & installed a 907 camping gaz cylinder in the only available space under the sink. He installed a vent through the floor & sealed , sort of , the cupboard door . I modified this whilst in the UK to enable me to use the 6.9kg UK propane cylinders.
I was hoping that on my return I would be able to use the similar sized repsol/cepsa cylinders but unfortunately they are to big in diameter for the locker as they have fancy plastic coats on. I can actually get the full size cylinders in but before I go down that route I was wondering about reusing the original tank ?
Now, firstly I've no idea when it was disconnected . It was manufactured in 1990 as that is embossed on it in 2" high figures . It has a capacity of 20L it says . It has a secondary smaller tank on the outlet ,I assume to flash off any liquid that may carry over, & this then feeds the regulator. Now the only thing disconnected/missing is the pipe from the regulator to the isolating valve before the manifold block.
I have thought of replacing the missing pipe & trying it but am concerned about whether the tank might have deteriorated, have rust inside , will regulator work, etc. I have even considered removing it & dismantling to see the condition , although this would entail remove the side panels as it is not possible to drop out from underneath.
I'd normally just think about buying a new tank & installing similar to what Tecno has just done but A , times are hard & B, it would have to come from the UK to be cost effective.
I'm leaning towards having it all off for a looksee but it is the regulator & whether it will function that is my main worry. Ideas & suggestions please & thanks in advance.
