mfh27748
:Angry:Help my omnistor step is not retracting it seems ok when i do it manually
common problem.. Had to fix mine on our apache 700 2 weeks ago before we left..
On the left hand side of the step (under the van) is a white square plastic section that contains a spring loaded switch. This gets cloged up with dirt etc..
If you locate it you can pull out the whole part, wires are attached to the rear so just pop it out and then spray in some switch cleaner (maplins) or use some light oil or WD40 to clean the crap out.. You should get the spring part freed and bingo.. Off you go.
The step will work via the manual switch but not by the ignition as the spring usually get stuck in the closed position and the system thinks it's already closed in..
greasing the step is not recommended as all of the road dust and grit sticks to it. a thorough clean is much better, clean off the grease grime and grit.I greased mine up and it works ok now.Tim Doherty
