Omnistor centre support rafter..
Discussion in 'Motorhome Chat' started by Charlie, Aug 16, 2015.
  1. Charlie
    Charlie Funster
    May 16, 2015
    2,448
    2,907
    Was looking at a Fiamma centre rafter today . Seems like a good idea when leaving the Thule Omnistor wind out canopy in place for several days . The one we saw had a neat LED strip light on it that was on a lead that went through the van window to power.
    The one we saw was at the show but was not for sale. I can find the rafter on EBay for 32 quid but can't find the light.
    So the questions.
    Is it worth adding the extra rafter support ?
    And can anyone recommend a strip light on 12 volt with a nice long lead ?
    It may be possible to take a feed or add a connector to the existing LED strip over the sliding side door on our Van Conversion. Not sure to be honest.
    Thanks.
  2. Charlie
    Charlie Funster
    May 16, 2015
    2,448
    2,907
    Oh. And they do a curved version of that rafter.. Opinions mostest welcome .
  3. Glandwr
    Glandwr Funster
    Jul 10, 2014
    645
    1,820
    the Berwyn Mountains
    I would have thought that it depended on the length of your awning. Ours is 4.5 mtrs and we had one supplied.
    Dick
  4. NickNic
    NickNic Funster Life Member
    Jan 14, 2014
    5,765
    11,810
    Kettering
    From your post you are looking at two different things.
    The Fiamma rafter is for Fiamma awnings. It won't fit a Thule awning.
    I don't know if Thule make one to fit an Omnistor awning but if they do that's what you will need.
  5. Charlie
    Charlie Funster
    May 16, 2015
    2,448
    2,907
    Sorry not so... The Fiamma is a far far neater job than the 3 piece Thule one which to be frank is bloody awful. Fiamma supply two extra rubber ends so it then fits the Thule Omnistor..
    Link
    http://www.ebay.co.uk/itm/181829690137?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
    Here is the link to the curved one
    http://www.ebay.co.uk/itm/Fiamma-Cu...n-144-265cm-/291435487228?hash=item43dae89ffc
    I just want to know if they are worth having. They seem so but its worth asking .
  6. carolyn
    carolyn Funster
    Jun 22, 2012
    694
    1,640
    Sherborne Dorset
    We have a new van with a 3.7 metre thule omnistor awning. I had seen the curved and staight rafter and it wasn't clear which I needed or why. At the Malvern show I visited Rose awnings to find out which I needed and why. He said it should have come supplied with one. The people who we bought the van from were at the show and kindly let us have a pole from their demo van rather than have to post one. This is a long white pole in 3 sections about 1 cm in diameter and not very strong I wouldn't have thought. Apparently this one just gives a bit of extra support but if you perhaps want it to stay up in more severe weather if you have sides and stuff then you need the more heavy duty rafter. The curved rafter was advised by a motorhomer with the exact model as ours, apparently the rain drains better. They had bought an extra thin pole and use one at each end for wind blockers. Have to confess I am still confused as to what the straight one is for. I don't know if this helps or not.
  7. NickNic
    Jan 14, 2014
    5,765
    11,810
    Kettering
    Sorry you're wrong. Fiamma don't supply anything to make it fit anyone else's product and that isn't what the eBay advert in your link says. The eBay seller by the way isn't connected to Fiamma. It's just one of many accessory sellers.
    It may well be possible to make it fit but that isn't the same thing and I would love to know both Thule's and your van manufacturer's opinion on warranty cover should any damage occur as a result of an incompatible product being bodged to fit.
    Up to you of course but I think it's a terrible idea. If you really want to do it I would at the very least suggest emailing both Fiamma and Thule for their opinion.
  8. Charlie
    Charlie Funster
    May 16, 2015
    2,448
    2,907
    The long white Three piece one is the Thule one I mentioned above. You are right it's not very strong at all. To be honest if they gave me one for free I would thank them and give it back..
    The Fiamma one is simple but strong and it's a two piece square section telescopic one.
    It was on display on the Lilipad stand. But as I said above it was not for sale as it was thier own one.
    It really is a case of Fiamma making a far better product .
    I just want to know if it's worth having and where I can get the 12 volt strip light with a nice long lead.
  9. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,823
    13,486
    Bolsover, Derbyshire
    we have an after market non manufacturer specific centre pole that is about as much use as a 'hand brake on a canoe' (not heard that one before tonights Dragons Den) it came with about 10 different end pieces none seem to fit, it has slipped out and scratched my MH
    Not really sure why I still carry it, just use good tie downs connected into the awning bead not over the top and slope the front to help rain water run off (y)
    edit - we have an Omnistor awning
    • Like Like x 2
  10. berni109
    berni109 Funster
    Sep 10, 2012
    316
    264
    worcester
    I was going to get a curved 1 but reading on here they can cause the material to stretch in hot weather.
    So I managed to pick up a straight 1 from a fellow funster. Gives a bit of tension to the centre and reduces sagging but if u are leaving it out in the rain make sure 1 leg is set shorter than the other to give a slope to the front bar. I would not leave out in a wind without straps.
    Hth
    • Like Like x 1
  11. Charlie
    Charlie Funster
    May 16, 2015
    2,448
    2,907
    With respect. It says clearly in the link it will fit the Thule Omnistor awning. It clearly gives the part numbers. I saw the very same product fitted to an Omnistor today..
    But worry not if I buy something that doesn't fit.
    Again all I want to know please is if these things are as good as they look ?
    • Like Like x 1
  12. NickNic
    Jan 14, 2014
    5,765
    11,810
    Kettering
    Yes it does say that but it isn't Fiamma or Thule saying it.
    If you buy it, fit it and damage occurs Thule will laugh at you whether it seems to fit correctly or not.
  13. Mousy
    Mousy Funster Life Member
    Sep 13, 2013
    2,153
    7,351
    Sa15 2DG
    Charlie, we have an ominstor awning with a fiamma rafter pole with the rubber end caps. it fits fine and stops the fabric puddling with water in the rain.
    I've heard the curved rafters cause the fabric to stretch in very hot weather.
    Lights can be purchased from eBay in metre strips.
    • Like Like x 2
  14. Charlie
    Charlie Funster
    May 16, 2015
    2,448
    2,907
    Lets start again.. I actually saw a Fiamma rafter fitted to a Thule Omnistor awning. It fitted very well indeed.
    It is/was not the fit I asked about it was how well these things work.
    I went to the Thule stand and looked closely at the rafters they sell that are specifically for the Thule Omnistor awning. Problem is is that they frankly put are crap. 3 or 4 sections of tubular steel that must have cost absolute peanuts to make and trust me I would not have bought one for a fiver let alone 37 quid.
    The Fiamma on the other hand is a well made two piece telescopic item that looks like it will do the job well and is worth the 32 quid asked.
    If I asked Thule you question what would I expect them to say ? " Well Charlie yes our ones are crap but we will get the sack if we tell you that or recommend a Fiamma one cos they are far better.
    Batter or scratch a Motor home with any rafter pole or whatever and no manufacturer is going to shell out for repairs. I would imagine 90% of these types of damage incidents are down to simply dropping or a slip of the hand anyway.
    For your information I bodge nothing ! If an alternative item is available however and as a bonus its better made does the job better costs less and actually works then I reserve the right to as questions to those who have actually used the products and recommend them as suitable and how good or bad they are.
    Thanks to those that have done just that. Answered my question with experience.
    But Nicknic I do appreciate your input. Just as I do anyone who helps an inexperienced novice in any area of motor homing like me.
    • Like Like x 4
  15. NickNic
    Jan 14, 2014
    5,765
    11,810
    Kettering
    I understand what you are saying.
    My point is only that if you fit a relatively inexpensive Fiamma rafter to your expensive Thule awning, attached to your even more expensive motorhome, something goes wrong and some damage occurs you can forget about any warranty claim either from Thule or whoever made your motorhome because you have used an incompatible accessory. How well it fits is absolutely irrelevant.
    We have a Fiamma awning so the Fiamma rafter works a treat on that (y)
  16. Charlie
    Charlie Funster
    May 16, 2015
    2,448
    2,907
    We have two spurious poles that hold the new Lilipad wind blockers.. So the risk increases..
    The poles that came with the Lilipad wind lockers were again really crap ! But those already reside in the skip and have been replaced with some more substantial ones..
    I take extreme care over my kit and can only hope the unthinkable doesn't happen.
    The Fiamma rafter has far far less potential to do damage than the junk Thule supply honest it does.
    Anyway it's ordered now so at least I can best myself round the head with it if nothing else eh ??
  17. Daveo2006
    Daveo2006 Read Only Funster
    Jan 25, 2013
    1,168
    987
    kent
    I wound my awning out once :LOL:
  18. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,533
    9,951
    to answer the questions
    yes they are worthwhile
    there is a model with lights prefitted....comes with a lead or on the electric fiamma just plugs in inside the box. the same can be done with self adhesive waterproof LED strips or a clip on LED light
    Best place to buy anything Fiamma is at @Johns_Cross_Motorhomes who also give a discount to members. They are the main uk stockist and what they dont know about the kit is not worth knowing. plus a bonus they will ship to campsites here or abroad if you need a part urgently
    as has been mentioned before..never rely on the rafter and legs alone to keep the awning safe and more rigid, ALWAYS fit tie down straps
    oh and the curved rafters are great till they get hot and distort the fabric
    • Like Like x 2
  19. Charlie
    Charlie Funster
    May 16, 2015
    2,448
    2,907
    Thanks.
    I have just ordered the ordinary Fiamma Rafter to which I'm going to add 59cm LED 12 V strip light.
    I always secure the awning down even if there is no wind around or forecasted.
    I will bear John Cross in mind next time I need kit.
  20. Mousy
    Sep 13, 2013
    2,153
    7,351
    Sa15 2DG
    I'd be interested in the lights you get.
