Omnistor awning leg wall brackets fitting (1 Viewer)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Unlike the Fiamma variety the Omnistor brackets come with NOTHING in the way of fixings.
Improvisation seems to be the order of the day.
I decided to use large flange button headed 6mm stainless steel set screws.
I chose a mounting position for each and drilled through the van sides 5mm holes.
My rear mount already has steel on the inside as part of the construction so I tapped this 6mm
I then opened the holes in the brackets out to 6mm. Cleaned all surfaces and applied any old Sikaflex leftovers.
Not just tapped but nylock nuts too
At the front having had to remove the batteries and trays I used a pre made bracket from B&Q as suitable steel
THERE IS NO NEED to overtighten ! enough is enough. The 6mm tapped studs take all the strain.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Concrete tarmac hard ground etc :thumb:
unclebobandcobwebs
3
Cambridgeshire
low profile coachbuilt
6 months
Bought a set of these at Peterborough - thought I'd use nuts n bolts with penny washers to spread the load inside. Hadn't thought of goling as big as M6 tho' it seems a good idea.:thumb:
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
£2.55 for 10 delivered
Broken Link Removed
Bracket at B&Q £2.98 as a guide
