Omnistep again
Discussion in 'Motorhome Chat' started by angusboy, Oct 13, 2016.
  1. angusboy
    angusboy Funster
    Nov 2, 2014
    603
    436
    somerset
    Hi guys we have power to switch, power to step fuses ok motor working step working in and out when hardwired by my fitter but will not work on switch, doing are heads in any ideas please need step working as wife has mobility problems kind regards steve
  2. JFD
    JFD Funster
    Apr 9, 2015
    130
    74
    Surrey
    Maybe I'm being thick, but doesn't what you describe mean that either the switch is duff, or the wiring from switch to step motor has failed?
    Maybe try taking a lead from the feed into the switch, direct to the step motor as a test. If this works, then move the lead to the output of the switch and, again, to the step motor, using the switch. If this fails, it's likely the switch, if it works, that points to the wiring between switch and step motor. If both work, then that would indicate it's one of the connectors you will have had to disconnect for the tests.
    Good luck!
    • Like it Like it x 1
  3. angusboy
    angusboy Funster
    Nov 2, 2014
    603
    436
    somerset
    thanks jfd think we tried most of this but will show fitter these posts regards steve
  4. andy63
    andy63 Funster
    Jan 19, 2014
    2,410
    9,481
    south shields
    the rocker switch has power you say but it also provides the circuit to battery negative... if nothing is working when switch is operated and power is there, check the lead from the back or the switch to battery negative ...
    andy
  5. angusboy
    angusboy Funster
    Nov 2, 2014
    603
    436
    somerset
    thanks andy will show fitter this regards
  6. andy63
    andy63 Funster
    Jan 19, 2014
    2,410
    9,481
    south shields
    heres a diag of the wiring arrangement on an omni slide out just in case its of any use.
  7. icantremember
    icantremember Funster
    Sep 2, 2010
    5,538
    7,670
    Nr Watton in Norfolk
    Sounds like a similar problem I had on our Autocruise which turned out to be a faulty Sargent EC400 power supply ... replaced unit and fault solved!
    Worth a call to Sargent, assuming yours is one of their units.
    • Informative Informative x 1
  8. angusboy
    angusboy Funster
    Nov 2, 2014
    603
    436
    somerset
    yes it is thanks
