Omni Step not working - low volts????
Discussion in 'Tech/Mech General' started by icantremember, Mar 4, 2013.
  1. icantremember
    icantremember Funster
    Sep 2, 2010
    5,208
    7,301
    Nr Watton in Norfolk
    My Omni step has been messing around, working sometimes and not others.
    I have replaced the step with a new one but still not working.
    All the batteries are fully charged.
    I checked the voltage at the fuse and getting full 12.7v (also checked the fuse)
    On checking voltage at the operating switch I'm only getting around 4.8v.
    I am assuming there is probably a poor connection somewhere but before I try to trace the wiring would like any advice please to confirm this is the likely problem or any other ideas.
  2. Terry
    Terry Funster
    Dec 27, 2007
    10,729
    6,234
    South yorks
    Take it off / strip down clean and refit :thumb: they are notorious for getting road crud on them
    Terry
  3. icantremember
    Sep 2, 2010
    5,208
    7,301
    Thanks Terry, but it's a brand new step & never been on the road.
    It is doing exactly the same as the old one which had some damage.
    The problem must surely be down to the reduced voltage?
  4. Terry
    Terry Funster
    Dec 27, 2007
    10,729
    6,234
    South yorks
    If that's the case then check the leccy bits and earth:thumb:
    Someone will be along shortly who may have a better idea where to check first
    What did you do with old step?
    Terry
  5. icantremember
    Sep 2, 2010
    5,208
    7,301
    Thanks again Terry.
    I still have the old step at present as a spare ..... I'm pretty sure it is ok except for a little visual damage.
  6. Diabalo
    Diabalo Funster
    Oct 14, 2007
    1,977
    383
    Rochester
    Brian,
    If you are getting low voltage one side of the swith it's the switch if it's both sides it's the feed, so work your way back. :thumb:
    • Like Like x 1
  7. shunter
    shunter Funster
    Sep 8, 2010
    532
    162
    Kent the white cliffs end
    It does sound like you have a earth fault Brian
    • Like Like x 1
  8. mogbl
    mogbl Funster
    Sep 28, 2010
    89
    173
    Castletownbere West Cork
    step
    I had the same problem although I did not check the voltage at the switch. Everything seemed to work fine except the step. It would work now and again it felt like it was sticking and the problem lay with the motor. Contacted the company who susgested new batteries. The batteries wer about two years old. Reluctantly I put new battries in and it did solved the problem.
    Richard
    • Like Like x 1
  9. icantremember
    Sep 2, 2010
    5,208
    7,301
    Hi Dane, cheers for that,it's both sides.
    I understand there is a relay somewhere in the system and wondered if this may be the problem.
    Brian
  10. Diabalo
    Diabalo Funster
    Oct 14, 2007
    1,977
    383
    Rochester
    There should be a relay that pulls the step in if it's out and you turn the ignition on. It could well be the culprit.
  11. icantremember
    Sep 2, 2010
    5,208
    7,301
    Update on non - working Omni step
    Right, after some testing I came to the conclusion the fault lay with the Sargent psu and last week had this confirmed by an auto electrician.:cry:
    I called the Sargent support line while we were away last week and having explained the situation they arranged for a replacement exchange psu to arrive with me this morning, which it did at 0930.:thumb:
    Around an hour later after much unplugging and replugging of so many connector blocks the new unit was fitted and ... hey presto .... a working step again.:BigGrin:
    One up to Sargent Electrical Services for great customer service.
    • Like Like x 3
  12. JockandRita
    JockandRita Funster Life Member
    Aug 2, 2007
    5,782
    7,522
    Lincs/Cambs border
    Great stuff Brian.
    Now you have a dodgy PSU, and a new set of steps to flog. :Laughing:
    Cheers,
    Jock.
  13. icantremember
    Sep 2, 2010
    5,208
    7,301
    Hi Jock, unfortunately the dodgy PSU is an exchange unit and has to be returned but I shall keep the spare step while we have this m/home in case of any mishaps.
    All the best,
    Brian
  14. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,533
    5,620
    Near Mold North Wales
    You mean if something GHOSTLY were to happen to it:Wink:
    Enjoyed meeting you over the weekend.:thumb:
    • Like Like x 1
  15. Daveo2006
    Daveo2006 Read Only Funster
    Jan 25, 2013
    1,168
    986
    kent
    My step on a brand new van with a brand new battery (which showed a full charge) didnt work properly.It turned out to be a dodgey battery and once replaced with a new one plus an additional one worked fine.Check condition of battery rather than take note of charge showing on control panel which is the mistake i made.
    • Like Like x 1
  16. icantremember
    Sep 2, 2010
    5,208
    7,301
    I must admit, I quite expected a spooky black mist to appear in the van if I got any wires crossed while changing the PSU:Doh:
    It was good to meet up with you at Chester & hope to see you again soon.
    Brian
    • Like Like x 1
