Omg mpg
Discussion in 'Tech/Mech General' started by andyetan, Sep 13, 2010.
  1. andyetan
    andyetan Read Only Funster
    Sep 7, 2010
    HELP!
    HI! I'm new to motorhoming and recently purchased a great little Fiat Ducato 1.9td Riviera 1000.
    The only thing I'm not happy with is the consumption, I'm only getting 20mpg from it, no matter how carefully I drive. It's a 1995 lhd with 40k on the clock.
    Is this normal? I thought it would be more frugal than that. Anyone else got one and getting better results?
    Andy
  2. hilldweller
    Dec 5, 2008
    26,864
    25,731
    Macclesfield
    Our 2003 2l JTD manages 25, but no better.
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,694
    17,305
    YO11 2BD
    26mpg at 55/60mph on mixed roads from our 2001 2.8ltr ducato.
    10mpg from our 6.8ltr V10 rexhall rv at 50mph (motorway) :Eeek:
    your 1.9ltr will be working much harder than the 2.8ltr to do the same amount of work.
    • Like Like x 1
  4. fugglestick
    fugglestick Read Only Funster
    Jul 24, 2010
    12
    Help mpg
    The easiest way to decrease fuel consumption is to slow down. When you double the speed of a vehicle, you need 8 times the engine power!!!!. Your engine is working a lot harder than a larger one, so 45-50 will be a lot more economical than 50-60. Just enjoy the scenery more....
    :thumb:
    • Like Like x 1
  5. acting_strange
    acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
    Sorry fugglestick but your premise is wrong......slowing down would increase the consumption.....mpg is about revs over weight....its about lowering the depression in the manifold and therefore the fuel ratio mixed with it:BigGrin:
    The depression increases towards idle and when you accelerate hard the balance is roughly 2500 to 3500 rpm
  6. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,551
    3,361
    Telford, Shropshire
    Sorry to disagree Mr Strange but Fugglestick is right and you are talking nonsense! For a start the manifold depression you mention only occurs in a petrol engine and your final comment just doesn't make any sense at all. The engine speed that is most economical will vary from one vehicle to another as it depends on the engine's state of tune, the aerodynamics of the vehicle its pulling and the overall gearing.
    To the OP low 20s would be my guess for a 1.9TD of 15 years vintage pulling a small coachbuilt bodied motorhome. The engine is on the small side and trying to push a vehicle with the aerodynamics of a small block of flats through the air. 50 to 55MPH is generally regarded as the best compromise of a decent travelling speed and acceptable fuel consumption.
    D.
    • Like Like x 3
    • Informative Informative x 1
  7. welsh winger
    welsh winger Read Only Funster
    Jul 7, 2009
    231
    58
    Sunny Swansea
    I have a 1.9td fiat, well till Wednesday that is, that another story, the first couple of times I used it, I was only getting 20 mpg, over the 12 months of ownership this did improve to 25/26mpg, why? I started using shell petrol rather than the supermarkets offering, every other tank I used the diesel version of redex.
    The main thing is as a driver you get to realise that slamming your foot to the floor is pointless, the van will get to speed in its own time, following on from acting strange saying its revs vs weight, on smaller engines the torque comes from a relativity high revving engine, which creates a small power band, like a 2 stroke engine, oh yes a diesel is a 2 stroke it "fires" every other stroke.
    In short use good fuel/redex, service the van a good quaintly oil will help, lastly and a simple answer to high consumption, are the brakes binding? lot of motor home owners don't use the van from one month to another, and expect to jump in it and away to go, sorry does not work that way. when I bought the 1.9td I spent a few hours cleaning and overhauling the brakes, which was well worth the time taken, better brakes and knowing they were not binding.
    There is a few points in my answer that may inflame other debates, the shell diesel for example, I personally have proved this to be true, on my van, car and motorbike, fuel consumption goes up when you use it, the van produces less smoke on start up, the bike goes like a scalded cat when on shell but hesitates on supermarket fuel, my car I have only had a month but has not had any other fuel in it from my personal experience, try it yourself.
    The torque question is simple higher revs create the torque, hence the smaller engined vans are often noisy and screaming their heads off, larger engines even non turbo are a more relaxed engine relying on the torque the engine produces, smaller engines work harder and use more fuel.
    I am picking up a 2.8 fiat on Wednesday, when I test drove it, I found that other than more torque the speed in the gears was not that different, the way it went up hills was very different, all down to torque.
    I expect a few comments disagreeing with this post, but as I have said this is my personal findings over owning 4 motor homes 2x 2.5D the 1.9td and now the 2.8D
    I need a lie down after this epic :Rofl1:
    Nick
    • Like Like x 1
  8. scotjimland
    Jul 25, 2007
    28,936
    25,589
    Optimal driving speed ?
    Those with fuel computers will know when they are driving at the optimal speed for best MPG .. those without it is a case of trial and error..
    I have trying to establish the best motorway cruising speed for my Honda CR-V .. I haven't come to a firm conclusion but over 65 it drops dramatically. So far the trial would suggest that it's between 55 and 65 .. higher or lower speeds reduce my MPG. but all vehicles have a different optimal speed. Finding it is the tricky part. !
    In order to better understand why, I searched and found this article that explains it..
    How Stuff Works
    An extract ...
  9. Jim
    Jim Ringleader
    Jul 19, 2007
    26,113
    77,200
    Sutton on Sea
    On a motorway, all things being equal, If I stay at a steady 54mph I get 9.9mpg. Travelling at 65 I get 7.5mpg, sometimes less.
    On a 3000 mile round trip in my RV, it pays to have a light right foot. :Smile:
  10. scotjimland
    Jul 25, 2007
    28,936
    25,589
    and deep pockets ... :Laughing:
  11. Jim
    Jim Ringleader
    Jul 19, 2007
    26,113
    77,200
    Sutton on Sea
    You bet, but, 5 up and the dog it was well worth it. :BigGrin:
  12. Wow
    Wow Trader - Engine ReMapping
    Sep 8, 2010
    68
    7
    Charlestown, Cornwall
    Your MPG is dire, we have and old N reg 2.5 on a 8.5m exhibition van and do much better than that :Sad:.
    Dave Newel is 100% right in what he's saying, take his advice along with Welsh Wingers about Shell and find you sweet spot as mentioned in ScotJimLands informative article and you will see improvement i'm sure:thumb:
    If you've done and its still bad, above all don't let it spoil your fun, just do slightly shorter or better planned journeys.
  13. shortfuse
    shortfuse Read Only Funster
    Apr 9, 2008
    38
    Inverness
    Hi Andy
    Our 1.9 td averaged 24 mpg ( measured over about 8000 miles )
    usually driving around 55 / 60
    regards sf
  14. 656
    656 Read Only Funster
    Jul 30, 2007
    1,150
    291
    The universe
    Sounds like a Re Map could help with the Torque. With the money back guarantee from WOW Tuning you have nothing to loose.
  15. dave newell lvs
    Oct 31, 2008
    2,551
    3,361
    Telford, Shropshire
    Except its impossible to remap a vehicle with no electronics:Doh:.
    D.
    • Like Like x 2
  16. DESCO
    DESCO Read Only Funster
    Mar 11, 2009
    2,651
    267
    London
    Had 1.9TD Fiat Swift Sundance but only for about 1 year (another story) and the best we could get was 23/24Mpg never got better.
    Dave :thumb::thumb:
  17. 656
    Jul 30, 2007
    1,150
    291
    The universe
    Ah, didnt know it didnt have an ECU.
  18. Issie52
    Issie52 Funster
    Jan 18, 2016
    13
    6
    Yorkshire
    We have had our 1.9 for 6 years and we get 30 mpg in ours ,we do put ametech Restore in with every fill up. Done over 55.000 km in it since we got it and it runs great.
  19. Boringfrog
    Boringfrog Funster
    Jul 13, 2008
    1,059
    485
    You used PETROL! no wonder your MPG decreased......;)
  20. eddievanbitz
    eddievanbitz Trader - Funster
    Oct 4, 2007
    3,605
    11,268
    Taunton Somerset
    But don't forget the faster you go, the sooner you get there, so you save 100% of the fuel Quicker
    • Like Like x 3
    • Thanks Thanks x 1
Similar Threads
  1. Jack Slipper
    48
    1,722
