Old Hymer 694
Discussion in 'Motorhome Chat' started by sillybug, Jul 17, 2015.
  1. sillybug
    sillybug Funster
    Apr 20, 2009
    131
    63
    norfolk
    ok we have an old 89 hymer 694 we go to france in 3 weeks and oh thinks clutch is failing but we cant figure out which one we need if he drops gearbox and clutch to get part number then we cant source the correct part we have a motorhome we cant move wondered if anybody has put a new clutch in a 2.5 td fiat ducato hymer and would no where we may find one. really need some help as oh is ready to give up on france this year and i really want to go . if all else fails does anybody no where we might aguire a newer 2003 plus, 694 or 754 privately. we have been looking for a while now and cant find something suitable maybe our expectations are to high but hayho really want something clean and tidy around 20-25.000 pounds all fhelp either new clutch or new motorhome much appreciated
    thankyou sillybug (teresa)
  2. nomadic
    nomadic Funster
    Sep 27, 2007
    673
    179
    Shropshire based
    Give the reg number to any parts organisation, CES is one that springs to mind, they should be able to quote the specific clutch, and price.
    You refer to a fiat chassis, it may be helpful, if you have that to hand at the same time, as its a m/h.
    Hope this helps.
    • Like Like x 1
  3. brianju
    brianju Funster
    Sep 18, 2007
    171
    35
    Hampshire Hogs now in Mid Wales
    • Like Like x 2
  4. s20hymer
    s20hymer Funster
    Jun 11, 2011
    273
    331
    Wiltshire
    hya my brother has Hymer 754 they thought the clutch was slipping and changed it... the plates were not worn it was the slave cylinder not letting clutch off..expensive
    • Like Like x 2
  5. Tootles
    Tootles Funster
    Sep 14, 2013
    9,125
    32,141
    Lancaster
    Type EPER into Google. This will get you to the FIAT database. Follow the links. It may require your VIN number initially, but will then come up with all the info on your chassis, engine and all FIAT base parts. Narrow it down to the engine section, and you will get a part number for the unit first fitted into your van, and a FIAT unit price. (y)
    • Like Like x 1
  6. countryman
    countryman Funster
    Apr 4, 2014
    19
    21
    suffolk
    Hi I am the one with a Hymer B754,i had a clutch fitted last year,thinking it was slipping but after new clutch,the slave cylinder was at fault as it was not releasing the clutch as it should,but all was good in the end.Would highly recommend VEHICLE SURGEON LTD Grundisburgh .Suffolk.01473 738385.They sorted mine out and they do MOT,s on all Motorhomes,servicing etc very good. One thing you could check is to see to make sure if it is Hydraulic or Cable, as 2 very different operations,one you can adjust and one you can not.ope this helps.
    • Like Like x 2
