ok, you got me! what is a B2B charger (1 Viewer)
sadlonelygit
155
95
forest of dean
Rapido
since 1975
i know it's battery to battery........
.............but how is it wired in and just what does it do?
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Its a voltage amplifier which provides a rapid 4 step charge to your leisure battery whilst your engine is running.
It will charge your battery 5 times faster and 20% more than the original split charge system.
Kiwi Coss
261
796
New Zealand
Is it worthwhile investing in? I have 3x 110watt batteries total 330 watt and I have run out of batt only once. We full time wild camp so depend heavily on the batts as a long time between electri hookups. also 180 watts solar panels.
Colin
Feb 16, 2013
19,505
51,186
uttoxeter
ambulance conversion
50 years
You have got to be driving though, if you are parked up for days on end it's not going to make any difference.
hilldweller
605
36,108
Macclesfield
Zilch Mk1
From Aug 2007
Yes it will. A one hour engine run will stuff in 5h of charge, allegedly, never tried one.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Heres an example,
We park up in the Alps for a weeks skiing.
There is little daylight because we are in a valley and it is winter. The roof is covered in snow, so solar is a waste of time (and bad for your batteries anyway, but that's another story).
We have the heating running 24/7 to stop things freezing, use the hairdryer a little, charge tablets, phones, etc and use the TV and lights as required.
After 2 days, the batteries are a bit discharged so I run the engine for an hour and a half whilst we have dinner. The habitation batteries are now fully charged and we wait another two days before running up the engine again.
Our battery bank is 345Ah and the Sterling Alternator to Battery charger charges at 90 amps on tickover.
A 50 amp battery to battery charger would take twice as long, but you get the idea.
sadlonelygit
sadlonelygit
155
95
forest of dean
Rapido
since 1975
so...........we have a 110a/hr battery with a 2k inverter (hairdryer and andrew james griddle thingy), so it seems like the dobrey that tricks the alternator into giving some serious juice is the answer.
so how easy/hard/friggin' impossible are they to fit, bearing in mind i'm quite happy to strip a motorcycle gearbox to bits................and get it working again:)
haganap
12,711
25,973
planet earth
Carthago C Tourer
I'm an oldbie MH number 9
I wired mine in and trust me.....
I'm proper thick ....
Would personally add another battery too if you can though....
lou020
488
355
huddersfield
autotrail chieftain
since 2010
i was always told, never rapid charge a vehicle battery as it shortens its life dramatically.
It should be trickle charged ?
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
If slow charging was best for batteries, our fleet of rental forklift trucks would need 6 batteries each to keep up with their shift patterns!
Our habitation batteries are now over 6 years old with full capacity still remaining. They have always been charged by a fast charging Sterling product.
Fast charging is only bad for batteries if you don't or can't keep the electrolyte topped up.
Open lead acid batteries lend themselves best to fast charging, sealed, AGM and gel types cannot be charged as rapidly, but certainly faster than with a conventional split charge system.
Terry
11,904
8,969
Lincolnshire
Can't remember ;)
Hi Jim knowing John if he says it's bad for them he WILL have experimented to find out why-they may not get fully (100%)charged or something :)-looking forward to his reply
terry
Sep 30, 2022
175
134
Rapido V68
I have a Rapido v68 with ECU, victron Mppt and shunt. Any idea how / where I would wire this into? Mkke
JockandRita
11,402
148,460
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Hi BOOMEL. šŸ‘‹
The thread you have posted in is about 9 x years old since the last reply.
It might be better to start a new thread, and copy and paste your question on there.
You could try a search as there are many threads covering your question subject.
Good luck. šŸ‘
Jock. šŸ˜€
Oct 7, 2013
5,867
36,736
South Wales
Swift Escape Compact
Since 1988
Thatā€™s better than my last effort!šŸ¤¬
Oct 5, 2019
380
264
Southport, UK
autotrail
im a newbie
hi i fitted the sterling b2b my self thought it was very easy ,,sterling will help you through if you ask them theres a chart to work out what cable size you need from the amps ,,and the length from battery to battery ,,there tech help is very good ,,a set of hydraulic crimps makes the job easy and not to expensive,, as i found out ,,
