Mr B
- Feb 1, 2015
- 990
- 1,889
- Rapido 7065ff Design Edit
- Since 2015.......
Top of the filter housing is fixed with four Pozidrive screws equally spaced around the rim.
D.
They are frequently rusted away to the point that a screwdriver will not grip, the only solution then is to drill the heads off then you can unscrew them with molegrips. I replace rusty ones with stainless steel screws.On ours these were very tight too.
John.
A sort of self tapper, doubt you can remove housing without access to the inside.Trying to replace the Air Filter and yes the Pozidrive screws are rusted. Are these self tappers or threads? Drilling out will be a nightmare, anyone know if it's feasible to remove the complete filter housing?
Thanks for the info both. Now that I see what i'm contending with I'll soak in penetrating fluid before I attempt to remove. Unbelievable design choice for a maintainable item, 3 spring clips would be ideal a la all other manufacturers. I've an A class so access very restricted.
Kevin
