haganap
- Dec 5, 2007
- 12,754
- 26,414
- Niesman+Bischoff 79e
- I'm an oldbie MH number 10
I am fitting a solar panel to my van and wanted to go through the current electic block thus making me able to see how much power was going to the batteries via the charging system..
I located my electric block here and this is the one. (in german though ) still managed a translation and there is quite clearly a plug in for what it calls solar Regulator. Why can I not just plug my Solar panel in to it?
is it just too simple to do this.
Regards/
Link Removed
I also found this which suggests it takes solar panels up to 220w Or am I dreaming/
EBL 208S, 208S Electric Block EBL 207-2 IT without display panel. A latest findings produced by a compact and universal power block for the 12 V system in the motorhome. An integrated charger 18 A (switching power supply), for gel batteries, provides for the charging of the battery housing or for power supply for recharging of the starter battery. The battery switch switches at low voltage of 12 V loads from the battery housing. Anschlussmöglichkeitenfür a solar controller are present (LR or LRS 1214 1214 for solar modules to 220 W). Secured outputs for 12 V distributed partly via relays. Incl. Batt. release relay, 12 V main relay switch - bistable, Batt.-breaker for shutting down the rest flows from the retirement of the vehicle.
Dimensions (HxWxD): 130 x 275 x 170 mm, weight: 1.8 kg
Regards/
Link Removed
