oil pump
Discussion in 'Motorhome Chat' started by hay, Feb 5, 2014.
  1. hay
    hay Read Only Funster
    Feb 5, 2014
    3
    blackisle
    I have an old fiat ducato 1992 1.9td I need information on oil pump where can I get a replacement
  2. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,678
    5,833
    Mansfield,Notts
    If you want to pm me vehicle reg I can check my suppliers for you
    Seems a strange request does that,unless your doing an engine rebuild I cant see the need of one, are you trying to cure an oil pressure problem if so I suspect your on the wrong track
    G
    • Like Like x 1
  3. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,052
    3,452
    walthamstow east london
    if you have low oil pressure its more likely to be worn bearings than an oil pump, in my experience they either work or it all goes bang
  4. hay
    Feb 5, 2014
    3
    blackisle
    oilpump
    we are rebuilding my engine and found that the oil pump has a problem the gear is thicker than the casting when plate is fixed it jams gear should there be a gasket it would need to be 8thou thick to give clearance my reg is k481cfs gratefull for any help.
  5. hay
    Feb 5, 2014
    3
    blackisle
    oilpump
    the pump was dismantled by someone else not available the gear is deeper than the casting when the cover plate is fitted it jams the gear should there be a gasket if so what material should be used regards j
  6. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,209
    12,573
    goole
Similar Threads
  1. 2bob
    4
    343
  2. Feltwell
    4
    309
  3. jemhorn
    17
    741
  4. EX51SSS
    295
  5. jointerjohn
    19
    872
