Oil Leak Peugeot 2.2hdi
Discussion in 'Peugeot' started by stevec, Jun 9, 2015.
  1. stevec
    stevec Funster
    Sep 24, 2013
    614
    207
    Norwich
    I've just been out to see about jacking up the MH to check the brake pads when I noticed an oil stain on the engine just by the join with the gearbox. It appears to be coming from where a black plastic box joins into the engine and that box sits just behind and above the starter motor. It has pipes that go to the sump and also the rocker cover so must be some sort of breather box. The junction into the engine appears to be a push fit circular affair about an inch or so in diameter. I'm not familiar with deisels in general or this engine in particular. Is this something to worry about. we are off to France in 9 days time for two weeks.
    Edit: This is on a 2006 X244 chassis. Engine has done nearly 21,000 miles. Oil is not dripping but stain has gone to bottom of engine .
  2. stevec
    stevec Funster
    Sep 24, 2013
    614
    207
    Norwich
    Bump.
  3. andy63
    andy63 Funster
    Jan 19, 2014
    2,079
    7,897
    south shields
    hi stevec, ive tried to have a look on line to see if I can identify the parts you describe as the breather system on your engine . does the black box look like the one in the link ill try and post.
    http://www.ebay.co.uk/itm/PEUGEOT-6...er-Pipe-Hose-ODMA-9641244780-C5-/271304696575...
    if its just a slight oil stain around a pipe joint on the breather I don't think you need worry... im not a mechanic
    but from messing around with engines all my life don't think what you see is unusual or anything to worry about..
    hopefully you will get more advice, but that's my views , if it is the breather pipes.
    ta andy.
  4. andy63
    andy63 Funster
    Jan 19, 2014
    2,079
    7,897
    south shields
    edited ...a duplicate post ..sorry
  5. stevec
    stevec Funster
    Sep 24, 2013
    614
    207
    Norwich
    Thanks Andy,
    Looks a bit like that. The starter motor blocks the view from below and there's loads of pipework at the front of the engine obscuring the engine block from above. Certainly a breather of some sort. I'll keep an eye on it over the next couple of weeks.
