Oil-filled radiators
Discussion in 'Motorhome Accessories' started by BobT, Feb 19, 2013.
  1. BobT
    BobT Trader - Tour Operator
    Jun 15, 2010
    305
    321
    Norfolk
    I have noticed that many funsters use oil-filled radiators when on hook-up or during the winter storage. In the past I have tried a halogen heater or 3 x 40 watt tubular heaters (greenhouse heaters).
    Can anyone tell me if the oil-filled radiators are more efficient and if so roughly how much will I need to pay for a good one?
    Many thanks,
    BobT
  2. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,336
    17,057
    Liverpool.
    Personally whilst the van is not used I have found a fan heater set at the frost setting to be the best as it only comes on when the inside of the van drops to almost freezing and circulates air better around the van than static heaters. The one I have is a switchable 1KW or 2KW so when the van is in use and we have hookup and the weather is cold we put it on the 1KW setting. This is OK on all hookups.
  3. hilldweller
    Dec 5, 2008
    27,885
    26,962
    Macclesfield
    All electric heaters are 100% efficient.
    There are two considerations:
    Safety.
    Heat distribution.
    Fan heater is probably best for sirring up the air, but not as safe and noisy.
    Oil filled is probably safest. Clothing can fall on it and not catch fire but corners remain cold.
    Greenhouse heaters and worst, lamp type heaters have little margin for error, catch the cable as you leave and you stand a good chance of an uninsured fire.
  4. Snowbird
    Apr 24, 2009
    10,336
    17,057
    Liverpool.
    Forgot to add, the one I use is a small catalytic fan heater with a fail safe device so that if it ever did get knocked over it would stop. I got it from either Aldi or Lidle. You cannot see any heating elements in it and using it on the frost setting it rarely if ever comes on, and then only for a short while.
  5. mike mcglynn
    mike mcglynn Funster Life Member
    Jan 6, 2008
    1,487
    6,776
    St. Helens MERSEYSIDE
    heaters
    Hi, Bob we always use a small oil filled one its about 700 watts they have some in our local costco they are £40 or thereabouts very efficient in our van
    • Like it Like it x 1
  6. Terry
    Terry Funster
    Dec 27, 2007
    10,808
    6,321
    South yorks
    I have a fan heater from Lidl and it has a remote control and is digital. This is easy to set and if you set it at say 24 degrees it will turn on and off within plus or minus 1 degree unlike 3 or 4 of the other fan heaters that can vairy up to 7 or 8 degrees before turning on :Sad:
    If they come on offer agian I will be getting another :thumb: I gave the oil filled one away as it was in the way and hot to touch
    Terry
  7. paulmold
    paulmold Read Only Funster
    Jun 15, 2009
    895
    301
    North Wales
    You can get ones between 650w and 800w for around the £20 mark from Poundstretchers, The Original Factory Shop and Dunelm.
  8. davanne
    davanne Funster
    Mar 16, 2010
    1,472
    7,458
    Carmarthenshire
    Tesco 500w oil filled about £20:thumb:
  9. Barclaybasher
    Barclaybasher Funster
    Apr 13, 2012
    2,479
    7,421
    Derby
    Tried a 600w heater and found it not enough, travelling, last Winter went back to 2000w oil filled on thermostat - in a well insulated Burstner:thumb:
  10. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,385
    18,074
    YO11 2BD
    you sure you dont mean Ceramic Dave ?
    a catalytic heater uses lpg and a precious metal catalyst such as platinum wire mesh....hence the high price.
    the gas reacts with the catalyst producing heat with no true burning of the gas
    basically a chemical reaction.
  11. Chris
    Chris Funster Life Member
    May 5, 2010
    16,853
    37,495
    kent
    I am sure a Funster had a problem with an oil filled radiator catching fire - so be careful.
  12. oldun
    oldun Read Only Funster
    Mar 23, 2008
    748
    160
    St Neots
    NEVER leave radiant heater on and unattended in small confimes as the radiant heat can heat up materials high enougth to catch fire.
    Tubular heaters designed for greenhouses (cheap) can often get very hot.
    Panel heaters (respond more quickly but expensive), oil filled radiators (respond slowly but cheaper) and fan heaters (respond the fastest, cheap but very noisy at night) are much better.
  13. Snowbird
    Apr 24, 2009
    10,336
    17,057
    Liverpool.
    Thats the one John :Doh:. A senior moment in my life. Bloody hell I seem to be having more and more of em :Sad:
    • Like it Like it x 4
  14. Bluemerle
    Bluemerle Read Only Funster
    Sep 22, 2011
    310
    316
    Out and about
    I use oil filled rad in my old prison truck, and its very effective.:Smile:
  15. oldun
    Mar 23, 2008
    748
    160
    St Neots
    That's about 30p an hour, quite expensive - for the campsite owner (unless metered!)
  16. motorhomelover
    motorhomelover Banned
    Jul 28, 2010
    1,719
    613
    The world
    HI I HAVE A 1.5kW YOU CAN HAVE FOR £30
    ITS ONLY 4 MONTHS OLD
    (I DO NOT USE IT AS I HAVE A CONVECTION HEATER THAT I LIKE BETTER)
    I GOT IT FROM ARGOS
    YOURS IAN
  17. scotjimland
    Jul 25, 2007
    29,044
    25,739
    Suffolk
    Yes indeed.. £7.20 per 24hrs..
    yet on another thread a member maintains that £5 for leccy cannot be justified as motorhomes could never use that amount..
  18. Barclaybasher
    Apr 13, 2012
    2,479
    7,421
    Derby
    Only stay overnight, travel every day, heater on for at most 8 hours - on a thermostat so not a constant drain - so probably less than 4 hours constant use = £1.20.
    I never complained about the cost of EHU but I don't motorhome in the winter to freeze at night.
  19. scotjimland
    Jul 25, 2007
    29,044
    25,739
    Suffolk
    sorry, I wasn't pointing the finger at you, only making the point that it's easy to use £5 of leccy in 24 hrs.
  20. Barclaybasher
    Apr 13, 2012
    2,479
    7,421
    Derby
    No apology needed - didn't think you were having a go.:Smile:
    Last Winter we used many different sites in England, Wales and France, they were very 'quiet' on more than a few we were alone.
    We were gratefull that at least some sites stay open all year round and I am sure that they were happy that at least somebody turned up.
    They wouldn't make money in the Winter months, but every little helps over the year.
    If EHU is included in the pitch price I would not use my gas for heating.....and I have no objection to a lower pitch price and paying for actual electric used:Smile:
