Oil change Dometic Tec 29 (1 Viewer)
Jun 30, 2011
7,234
20,094
Barnard Castle, UK
Concorde Concerto
I am trying to work out how to change the oil on the above genny. Could anyone talk me through it.
I can see the drain tube when I open the front cover, is there also a drain plug or do you just undo the high point of the drain tube and the oil comes out.
Many thanks.
Paul n Caroline.
43,323
49,428
I believe some genny's are drained by syphoning from the filler tube
do you have a picture?
sorry, just re-read your post.....i think the pint i just had has fuddled me brain,
i would think the drain tube is attached to a drain bung and just loosening it will allow oil to flow out.
CazPaul
Jun 30, 2011
7,234
20,094
Barnard Castle, UK
Concorde Concerto
Thanks Pappajohn
Here is the picture, you can see what i think is the drain tube, if i disconnect the high point of it will it just drain, or is there also a drain plug to undo.
Paul.
