ohms law
Discussion in 'Tech/Mech General' started by betterthenatent, Mar 19, 2011.
  1. betterthenatent
    betterthenatent Read Only Funster
    Aug 23, 2010
    38
    Can anyone refresh my memory on ohms law. We are having our first trip of the year next week and I thought I might take a 1-2 w fan heater will this be OK on a hook up. A few examples would help.
  2. Munchie
    Munchie Funster Life Member
    Jul 28, 2007
    8,575
    11,763
    Champagnac-La-Riviere
    OHMS law states that the current flowing in any conductor is directly proportional to the EMF and inversley proportional to the resistance providing the temperature remains constant. :Eeek:
    If my memory hasn't failed me. :Rofl1:
  3. peter H
    peter H Funster Life Member
    Jan 18, 2008
    1,350
    662
    Neath, South Wales
    Power (watts) = Volts X Amps
    or
    Amps = Watts / Volts
    so
    2000 watts / 240 volts = 8 amps approx
  4. callumwa
    callumwa Read Only Funster
    Jan 16, 2011
    4,113
    4,517
    Tyne & Wear, sometimes..
    P = I x V
    Power (P) in watts = (I) current in Amps x (V) Voltage in Volts
    1 Kw rated heater is 1000 watts, so at 240 volts is drawing approx 4amps....
    2Kw (2000 watts) drawing approx 8 amps... and so on..
  5. betterthenatent
    Aug 23, 2010
    38
    Thanks for the replies. I sort of had an idea that was it but some how I thought a 1kw appliance would draw more currant.
  6. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    ohms law = oh my god, the whole site has gone out!:Wink:
  7. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,469
    881
    South Glos
    Not wishing to be pedantic but ohms law makes does no reference to power.
    Ohm's law states that the current through a conductor between two points is directly proportional to the potential difference or voltage across the two points, and inversely proportional to the resistance between them.
    The mathematical equation that describes this relationship is: I = V/R
    where I is the current through the conductor in units of amperes, V is the potential difference measured across the conductor in units of volts, and R is the resistance of the conductor in units of ohms. More specifically, Ohm's law states that the R in this relation is constant, independent of the current.
  8. Simannjo
    Simannjo Read Only Funster
    Apr 18, 2009
    31
    Nottingham.
    Ohms law = have on what you want untill the post trips...
  9. bigfoot
    bigfoot Funster
    Dec 23, 2007
    4,002
    5,170
    Wirral
    Ohm sweet ohm
  10. Gromett
    Gromett Funster
    Feb 27, 2011
    7,998
    14,361
    UK
    Draw a triangle on a piece of paper. Put the letter V at the top.
    Put an I at the bottom left and an R at the bottom right.
    Cover the one you want to find out with your finger and what is left is the formula.
    For example you want to know what V is. The answer is IR
    You want to know what I is. The answer V over R (V/R)
    Power is Current X Voltage. Using ohms law and transposition of the above formulas you can work out.
    W = I2R (I Squared x R)
    W = IV
    W = V2/R (V Squared over R)
    There are 12 formulae in total using these 4 variables.
    Bear in mind though that these only apply to resistive loads only. When you get into capacitive and Inductive loads you have to take Xc and Xl into account. These are Inductive Reactance and Capacitive Reactance but don't worry too much about these if doing rough and ready calcs for cabling etc.
    However when working on 12V car gear, remember that the voltage can be as high as 14.4V when working out current flow in cables. :Eeek:
    Karl
  11. Gromett
    Gromett Funster
    Feb 27, 2011
    7,998
    14,361
    UK
    Sorry my previous answer didn't answer your question.
    W = IV.
    Tranposed
    I = W/V
    Quick a rough way I use is each 1KW is 4 Amps. Not totally accurate but close enough for checking if a breaker will cope with a 1KW heater etc.
    Karl
  12. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,552
    3,361
    Telford, Shropshire
    You're not going to get much heat out of a 1-2 watt heaterr though:Rofl1:.
    D.
  13. MicknPat
    MicknPat Funster
    Dec 16, 2007
    628
    2,957
    Touring UK
  14. DBSilverfox
    DBSilverfox Read Only Funster
    May 13, 2010
    592
    98
    Nottingham
    When I was at school they taught us to remember it as the girl's name - Ivy Watts. (I x V = Watts), and use the triangle trick.
    Always stuck.
    David
  15. golly
    golly Funster
    Aug 16, 2009
    1,124
    2,058
    Co Durham
    Don,t forget when calculating your total Amps to take account of the battery charger and fridge etc. I have a card with the amps used by each appliance I use, then I know if I have to switch anything off before putting say the kettle on. Sad I know but better than tripping the post or even the site supply.:Eek!:
    John
  16. scotjimland
    Jul 25, 2007
    28,934
    25,590
    Now that's been done... :thumb:
    could someone explain E=mc2 (in laymen's terms) :Laughing:
    Karl ?
  17. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,684
    5,840
    Mansfield,Notts
    Not sure on the fine details, but it has to do wit Museums:thumb:
    Ohm is where the art is:Cool:
  18. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    there you go.
    [​IMG] where E is energy, m is mass, and c is the speed of light in a vacuum. The formula is dimensionally consistent and does not depend on any specific system of measurement units. For example, in many systems of natural units, the speed (scalar) of light is set equal to 1 ('distance'/'time'), and the formula becomes the identity E = m'('distance'2/'time'2)'; hence the term "mass–energy equivalence
  19. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    That sounds a good idea to me :thumb::Rofl1:plug it in -if it works its OK :Rofl1::Rofl1::Rofl1::BigGrin:
    terry
  20. scotjimland
    Jul 25, 2007
    28,934
    25,590
    that's not Ohms law... that's Murphy's law :Doh: :Rofl1::Rofl1:
Similar Threads
  1. voyager14
    7
    501
