Oh Oh !! (1 Viewer)
Jul 29, 2011
2,696
22,122
Urmston, Manchester
Former owner.
June 2012
Decided to hitch the trailer on today for the first time, thought i had better check that the electrics work ok.::bigsmile:
Open the socket to plug in and found that the trailer plug has 7 pins and the motorhome socket has 13 holes.:Eeek:
Was going to see an auto electrician tomorrow to fit my new reversing camera now i've got another job for him to sort out. More expense. :cry:
Why is there a 13 hole socket ?
chatter
3,689
937
cheshire
5th wheel
maybe whoever used to own the vehicle before you (if someone did) used to tow a caravan with it as well, 13 pin is the newish euro standard socket for caravans
Jaws
23,832
72,342
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
The standard Euro socket has 13 connectors for a caravan, rather than as used to be, twin 7 pin connectors..
The old idea was the black 7 pin plug dealt with the trailer lights while the white ( or grey ) 7 pin plug ran the battery charging and fridge in the caravan
You can either put a 13 pin plug on the trailer or replace the 13 pin with a 7 on the van
Orrrr. you can buy a converter ( which is not my idea of great as it introduces yet another possible breakdown point ! )
old-mo
Extra Special
16,343
93,570
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
I have a German constructed trailer. (I think)...:RollEyes:
Anyway it came with a normal seven pin plug....... I had to extend the wire as my socket was right under the RV and the trailer would not reach....
I was suprised when I took the plug off it was a seven (7) that had been plugged into a 13 pin plug...:Eeek:
So out there some where you can buy a 7 into 13..
Just had a look on fleabay..... loads of them.. like this one.. Item number: 200801952614 :thumb:
Type this into Motors... 7 - 13 pin trailer plug..
Not expensive either.... expect it is cheaper than paying n electrician to sort it.. :winky:
old-mo
Extra Special
16,343
93,570
Weymouth. Dorset...
There OK, John.... :thumb:
Just wack plenty of "Vaseline"... up the holes... :Eeek::winky::ROFLMAO:
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
That has got me into trouble more times than its got me out of trouble in the past Old Mo
PaulyP
Jul 29, 2011
2,696
22,122
Urmston, Manchester
Former owner.
June 2012
Thanks to Steve for the link, ::bigsmile:::bigsmile: didn't see it at first.:Doh:
Been on fleabay and bought one, much cheaper than paying an auto electrician, thanks to all for similar advice, why did i not think of an adapter ?
Just thought electrics and it will cost me.:thumb:
Jaws
23,832
72,342
Thetford Norfolk
C class, Chieftain
Pauly, if electrics phase you ( pun intended ! ) get your self down to Wildmans and do the class he is going to do..,
Once you have basics the rest is really easy :thumb:
old-mo
Extra Special
16,343
93,570
Weymouth. Dorset...
WAYYYYY to much information !!!!
Sorry you two have lost me....
I was told that Vaseline stops or helps stop the ingress of water and stops electrical contacts from corroding..::bigsmile:
PaulyP
Jul 29, 2011
2,696
22,122
Urmston, Manchester
Former owner.
June 2012
Unfortunately i will be in the North Sea during that time, got to earn the money to pay for all the things i want to do.
I am getting better at the electrics, just not always confident about it.
Pikey Pete
1,481
1,143
o
o
I don't want to rain on your parade but the 2 adapters I saw on fleabay had Female 13 pin ends and your van photo shows a 13 pin female.
So that isn't going to work.
Pete:Cool:
Jaws
23,832
72,342
Thetford Norfolk
C class, Chieftain
Think another look then Pete..
First one I saw was this..
Link Removed
QUOTE:
Maypole towing electrics conversion adaptor
Converts N Type 13pin vehicle electrics to 7pin caravan & trailer electrics
Input:
1 x 12v N Type
Output:
1 x 7pin connector
Pikey Pete
1,481
1,143
o
o
Link Removed
Input:
1 x 12v N Type
Output:
1 x 7pin connector
My point was that the adapters recommended on this thread one via a link and the other by ebay number were both the wrong way round. So if the OP has bought either of those he has the wrong part.
Pete:Cool:
PaulyP
Jul 29, 2011
2,696
22,122
Urmston, Manchester
Former owner.
June 2012
Cheers Pete,::bigsmile:::bigsmile: well spotted, have changed my order the same seller has the correct adapters. Should have seen it myself.:Blush::Blush:
Jaws
23,832
72,342
Thetford Norfolk
C class, Chieftain
Oh right.. I read your post as the ones you saw were the wrong way round so I responded with the ones I saw were the right way round..
I did not suggest anyone had made an error merely that both types were available
Sorry, not really used to pedantry on Fun
