oh bugger
Discussion in 'Tech/Mech General' started by stumpy, Nov 23, 2008.
  1. stumpy
    stumpy Deleted User
    I took off the rear intirior panle in the back of the van to find very very rotten and wet wooden battens .The rear lights are leaking ,i can sort the leak but is there something i can paint on to stabalize the rotton wood ?One of the wardrobes will need to be taken out but i can see it will never go back as factory fitted any advice ?:Doh:
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    Rotten wood should ALWAYS be removed before the rot spreads. Rot is a fungus and even when it dries out the spores will spread, cut it out, leave long enough to dry right out then replace it with new treated timber. Treat whatever is left with a specialist timber treatment. Leave the cladding off long enough to prove you have cured the leak and for surrounding areas to dry.
  3. Bulletguy
    Bulletguy Read Only Funster
    Feb 7, 2008
    2,051
    6
    Cheshire/Staffs
    False economy.
    Best ripped out and replaced with new wood. But use quality hardwood and not cheap crap soft wood which i'm betting the orginals are(?). Manufacturers do things like this to keep the costs down, and people don't ever see battens........until like you they find damp and rip the panel off.
  4. stumpy
    stumpy Deleted User
    your only confirming what i thought :cry:i dont want to rip out Talullah's back end :cry: next year it will be now :Eeek:
  5. Wildman
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    Just replace what you can see behind the panel for now.
  6. stumpy
    stumpy Deleted User
    lucky i can get to most of the rot,but the only concern is i have to take out the factory fitted wardrobe.Dads coming down so i'll get him on to it see what he thinks :Wink:like all dad's he can do it better than the boy :BigGrin:thank god :BigGrin:
  7. lugnutt
    lugnutt Funster Life Member
    Sep 9, 2007
    1,185
    456
    wednesbury.westmidlands
  8. Shore-is-Good
    Shore-is-Good Read Only Funster
    Aug 26, 2008
    46
    Somewhere warm
    I'm so pleased I have a quality German 'van which is constructed from aluminium sandwich material. No wood anywhere in the exterior body construction to go rotten. Sorry, don't mean to come over as 'smug' but I now see the point of paying more for a quality item. :RollEyes:
  9. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,992
    40,249
    Dont you beleive it,,
    At least with "Stumpy`s" and the wood framed build you do have the chance of replacing rotten parts and the wood,,
    Sandwich construction is known to break down and delaminate,, there is no quick fix if this happens,, it can be a major job.. I know I had it happen on a modern caravan..
    Big flat bubbles that just got bigger and bigger..
    A lot of caravans and MH`s do have wood all round the corners,, even sandwich construction`s,,
    Any water ingress can start rot and delamination,,
    Best to nip it in the bud..
    Check your corners and seals,, at least once a year..especially the sealant around your roof and gutters.. the most common area for seals breaking down is on caravans which frequently use an awning the preasure and strain put on the awning channel in windy conditions is tremendous,. The awning rail/channel is only held on by a few screws and a bit of sealant..
    Sealant that is not cleaned frequently will get moss growing and the roots of moss are very strong and will find it`s way in the smallest crevise,, try pulling up a bit of moss from in between close butted paving and see how far the roots go down..
    Just my two penneth..
  10. badger1
    badger1 Read Only Funster
    Jan 8, 2008
    16
    forest of dean glos
    Hi Stumpy, some years ago I had a rotten window cill on the house and with winter in full bloom did not want to start ripping things about. In my local builders merchants I found a product that one painted/soaked the rotten timber with,which after a few hours turned the soft timber into something resembling teak,ie rock hard. Then when all was dry, a quick coat of polyester filler and paint and it looked ok. still no probs with it 6 years later.
    When it was eventually ripped out due to replacement with UPVC windows the timber was still solid. Cannot think what it was called but I have seen similar product in B&Q .
    May be worth a look round the outlets. Regards Badger1
  11. stumpy
    stumpy Deleted User
    My history is old vw's which rot like it's going out of fashion. But this is my first modern camper (1973)and only cost £3000 and ive found with your quality i carnt belive how much they cost :Eeek:some of you guy's spend mega buck's :Eeek:
    Lugnutt id crap my self if it was that bad very good link thou:BigGrin:
    Badger1 yes my mate told me about that might a temp option gonna look into it ,and replace it next year :Wink:
  12. Shore-is-Good
    Aug 26, 2008
    46
    Somewhere warm
    I do...I've been to the factory in Germany and seen 'em built - def no wood! The alum. sandwich material is stated to be guaranteed 'good for 20 years.' But, hey, when you've shelled out as much for a M/H as for a small house, you expect something special.
  13. Bulletguy
    Feb 7, 2008
    2,051
    6
    Cheshire/Staffs
    Big difference and not a good comparison.
    A small house, even modern build crap, will not only last a heck of a lot longer than 20 years, it's an appreciating asset unlike any m/h or rv which depreciates in value from day one.
    A small house will cost anywhere around £120 - 150k. Anyone spending that amount on a m/h or rv either has money to burn, or needs their head examining.
  14. Shore-is-Good
    Aug 26, 2008
    46
    Somewhere warm
    I guess that describes me, then, on both counts!...except the amount spent was higher than your figures...but it matters not: 1) I'm having a blast and 2) We're spending the kids inheritance...and furthermore - they approve! :thumb:
  15. stumpy
    stumpy Deleted User
    Your my new bestest friend ever :Rofl1:you can be my Motor Homeboy :BigGrin:
    Gangster motor homeboy's :Rofl1:
  16. wiljoy
    wiljoy Funster
    May 23, 2008
    919
    999
    Crook, Durham
    Hymer quality??
    Hi, I bought Hymer quality a few years ago and it lasted 7 months. The delamination was so bad they took it back and gave me another. I sold this very soon as this quality is crap in my eyes.
    Wiljoy
  17. ricwig69
    ricwig69 Read Only Funster
    May 1, 2008
    42
    Newcastle (The Toon)
    Just so long as you don't mean to come over as 'smug'...:Wink:
  18. old-mo
    Oct 16, 2008
    12,992
    40,249
    :Rofl1::Rofl1::Rofl1:
  19. camcondor
    camcondor Read Only Funster
    Jul 27, 2007
    1,044
    478
    East Midlands
    Brilliant! Well put - everyone has the right to spend WHAT THEY WANT TO, whether its on a motorhome or anything else!! Your Concorde is a fab motorhome and I wish you well with it - its certainly not up to anyone here or anywhere else to pass judgements on what people spend on motorhomes - not all motorhomers want to buy an elderly cheap motorhome and can spend very high amounts on their lifestyle of choice, while others may want to restore a much cheaper option, but no-one has the right to dictate or pass judgement on the motorhome choice of others, whatever the costs may be!!:RollEyes:
    Have a blast in your Concorde and ignore the appearance of the Little Green Man who has a habit of surfacing from time to time!!!:Rofl1::Rofl1:
    Laurie
  20. Shore-is-Good
    Aug 26, 2008
    46
    Somewhere warm
    Thank you Camcondor - Amem to that! Graciously said and appreciated...I, too wish you all the very best with yours. May see you on the road someday :BigGrin:
    • Like it Like it x 1
