Off tomorrow
Discussion in 'Motorhome Chat' started by Hussar, Apr 22, 2010.
  1. Hussar
    Hussar Read Only Funster
    Aug 22, 2009
    48
    Having spent only one night away in the "Tardis" so far. Myself, Mrs Hussar and the two dogs are off for the weekend tomorrow.
    Spent the day loadng up with bits and pieces including my telescope, hopefully be able to get away from too much light pollution.
    I did however make one small cockup earlier today. I decided to change the gas cylinder as the level of the original (butane) was unknown. I purchased a 13kg propane cylinder and dug out an "old" regulator from the garage.
    Connected it all up, opened the cylinder valve and went to the hob to bleed gas through, promptly blew the burner tops off. Apparently it is best not to blast 2 bar of pressure through the gas plunbing....!!!!
    All ok after adjusting the regulator.:Eeek:
  2. gwnking
    gwnking Read Only Funster
    Sep 29, 2009
    521
    East Anglia
    Enjoy your time away and without mishaps
    Dale
  3. gazz
    gazz Formerly "gazznhelz"
    Mar 16, 2010
    142
    Eastwood, Notts
    good job you didnt try lighting it then,
    mind i bet the kettle would have boiled a little faster than usual... like in 2 seconds :)
  4. wasp
    wasp Funster
    Dec 21, 2008
    2,729
    1,066
    Mansfield
    On that note you should be using the fixed pressure regulator and not the adjustable one, they are made for blowlamps:thumb::thumb::thumb::thumb::thumb:
