Obscure Part Required (1 Viewer)
DBK
18,009
48,003
Plympton, Devon
PVC, Murvi Morocco
I have managed to break the plastic hinge pin on my electrical socket and what's left of the pin isn't long enough to be used. I could bodge something with a bit of wire or strimmer cord but would prefer the right bit if possible.
I have tried Googling but without success. Does anyone know the proper name for this pin, if it has one, and more importantly where I might get a replacement? You can see the missing bit of the pin in the picture below.
Scout
3,958
120,915
South Yorkshire
chic c line
12 years motorhoming, a lifetime of living
I think youll find it allmost impossible to get a pin, I would drill it out and fit something made up, puting a spot of superglue near the outside edge just to hold it in
Reactions: DBK
Nov 18, 2011
11,862
42,801
Planet Earth
A van
Over 25 year's
I done the same on my last van I used stainless wire and araldite but you culd use small stainless sprung role pins that was recommended after I had fixed it that repair is still good to this day a bit off brass brazing wire might work to
bill
Reactions: DBK
Lenny HB
53,309
149,500
On the coast in West Sussex
Hymer B678 DL
The pin is only supplied with a replacement cover and the cover is only about a quid less than a complete socket, as others have said best to make something up yourself.
Reactions: DBK
DBK
DBK
18,009
48,003
Plympton, Devon
PVC, Murvi Morocco
Thanks all - looks like I need to put my bodging hat on. :)
Nov 18, 2011
11,862
42,801
Planet Earth
A van
Over 25 year's
if you bodge it will be better than original materials wise cost of repair 20p it's cost more to run the computer to post the problem
take out the pin and use that as your guide for gauge of pin
bill
Reactions: DBK
43,299
49,286
Correct sized piano from a craft or model shop.
You may need to buy a meter length and you need something to cut it with......side cutters/pliers WONT cut it.
Reactions: DBK
DBK
DBK
18,009
48,003
Plympton, Devon
PVC, Murvi Morocco
I've done a temporary repair with a bit of strimmer line, it isn't quite the right diameter but it will hold for the moment and it's too cold outside to hang around for long! I removed the other pin and passed the line all the way through then squeezed the ends so it shouldn't fall out. The neatest solution as already suggested would be stainless steel roll pins or a couple of fine SS self-tappers. Something like these in the 3mm size I think: http://www.ebay.co.uk/itm/like/1607...1=ICEP3.0.0-L&ff12=67&ff13=80&ff14=108&ff19=0
Perhaps we need a new thread "This Week I Bodged..." :):):)
DBK
DBK
18,009
48,003
Plympton, Devon
PVC, Murvi Morocco
Further to the above I've just ordered a pack of 4 stainless steel roll pins from that site, 30mm by 3mm for £1.99. I'll tell you if they fit when they arrive!
Of course the disadvantage of these will be they woill be very strong and I think the idea of the plastic pin is it gives before the cover. So the next time I brush against it I will be needing a new cover. :(
Aug 6, 2013
11,950
16,556
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Before you bought the roll pins I was going to suggest plastic knitting needles - available in a multitude of diameters.
UK Pete
284
333
kent
Renault van conversion
on/off since 1991in campervanss
mine has just snapped exactly the same as that, they are so brittle in this cold weather
Reactions: DBK
UK Pete
284
333
kent
Ok here is what i just done to fix mine, i got a rivet of the correct size, slid off the collar then attached it through the holes and glued it in place on the inside
Sep 29, 2009
197
60
norwich
swift escape 640
since 2009
i had to do a repair the other day to something like this and used the centre pin from black plastic rivets. made a nice finnish
Reactions: DBK
DBK
DBK
18,009
48,003
Plympton, Devon
PVC, Murvi Morocco
Thanks sounds good. I am inclining towards something which is not too strong.
marjohn
129
60
lowestoft
c class
9 years
Use two tapered dowls one in each end
