oberholtz door lock
Discussion in 'Motorhome Security' started by betterthenatent, Aug 28, 2010.
  1. betterthenatent
    betterthenatent Read Only Funster
    Aug 23, 2010
    38
    Hi I Have posted this question on another section of this forum, but then I noticed this section. So here goes again. I have just bought our first motor home, an autoquest 200. It has an oberholtz door lock fitted to the habitation door and I cant Lock it from the inside. Is this normal.
  2. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
  3. betterthenatent
    Aug 23, 2010
    38
    not to hand but if you google MLN073020 that is the part number for this lock from one company that sells them and they have a good photo. In fact if it should lock from the inside and mine is faulty. I will use this photo to help me strip it down and have a go at fixing it.
  4. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    From the pic I would have thought that the inner Knob would twist to lock...Does the inner button press in to allow this?
    Doesn't make sense if it won't lock from the inside for your security....
    Might well be faulty...Anyone else any ideas or got a unit with a similar lock fitted?
    [​IMG]
  5. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
  6. acting_strange
    acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
    Ok this is the same lock as I have in my Lunar....to lock from the inside all I normally do is twist the "winged" bit to the left.
    Ii is normally to the right when unlocked.
    can you not do this? if not are you sure the door is fully closed...i do find with mine that you have to amke sure and pull the door hard to make sure its closed.
  7. ninjayorkies
    ninjayorkies Read Only Funster
    Mar 28, 2010
    533
    148
    Lutterworth
    That looks like the same lock on my Bessacarr - just twist it to the left to lock but I make sure I slam the door shut first
  8. betterthenatent
    Aug 23, 2010
    38
    I figured that turning the knob to the left should have locked the door, but it just wouldn't turn, and I didn't want to force it. So armed with the photo that American dream posted. I striped the lock down to see how it worked. I think it must have been taken to pieces sometime in the past, as one of the screws is different, also I have a key that is the same shape as the door lock but doesn't fit. So maybe the barrel has been replaced. Any way I got the lock working on the bench ant then refitted it and now, touch wood I can lock the door from the inside. Sorry for the delay in replying but I had to sort out my registration. Thanks all for your help.
    :thumb:
  9. hilldweller
    Dec 5, 2008
    27,552
    26,647
    Macclesfield
    We have one of those - it MUST go click+click. Single click and it will not turn.
  10. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Glad you sorted it.:thumb:
