Numpty question? (1 Viewer)
hdvrod
859
733
devon
coachbuilt
since jan 2011
Apologise for what may seem a stupid question,but this is our first motorhome and bought privately with no instuction manual.The pic I have attached is our control panel and at the top is a rocker switch with a symbol of a car at the top and a caravan at the bottom,assume the bottom one is for the leisure battery and the top one the vehicle battery,is this correct?
and can I run the 12v electrics from either,on mains or not?Thanks:Smile:
Terry
11,932
9,073
Lincolnshire
Can't remember ;)
Hi usually means the L/ batt is charging on caravan and switched to car will charge the engine battery --All when on Hook up :thumb: Check with a multi meter :winky: just because you have it showing does not mean the converter did it / wired it like that ::bigsmile:
terry
highwayman
968
1,029
Herne Bay
Low profile Rapido
Since 2005 ish
Yep and Yep
but don't run much off the vehicle battery cos they're a bugger to push start :roflmto:
cheers nige
highwayman
968
1,029
Herne Bay
Low profile Rapido
Since 2005 ish
By the way, the only daft question is the one not asked when you should have :thumb:
cheers nige
43,319
49,388
if its fully wired then yes, you can charge (from your onboard charger) or use either battery.
in the centre position neither battery is connected but you may be able to still use 12v stuff direct from the charger (to its output limit).
only use the engine battery in emergency...or you may end up with a flat engine battery.
if you're on hookup you will be using the charger to power 12v stuff with the battery acting only as a secondary supply incase you exceed the chargers output.
