not motorhome related but LED related
Discussion in 'Tech/Mech General' started by Jaws, Aug 7, 2016.
  1. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,593
    22,679
    Narrfoook
    I am looking to replace some 5ft fluorescent fittings with an LED equivalent
    The current ones are rated at 60w with the light output you would expect
    I am looking for strip LED fittings that will give at least equivalent light output and have a similar housing ( so as not to have to redo the whole ceiling again :) )
    Anyone have any suggestions ?
  2. olley
    olley Funster
    Jul 29, 2007
    3,762
    2,273
    Ipswich
    • Like Like x 1
  3. Jaws
    Sep 26, 2008
    18,593
    22,679
    Narrfoook
    Cheers Oiley,
    And that really emphasises the problem !
    There are SO many options available. I am really looking for definitive answer as to what equals a standard 65w unit :)
  4. Jaws
    Sep 26, 2008
    18,593
    22,679
    Narrfoook
    A more precise question..
    I can find the lumen output and colour temperature of the LED jobbies, but not of the old fluorescent fittings..
    So I am after the figures for the old units so I can match them with the new LED ones ( if you see what I mean :) )
  5. Boringfrog
    Boringfrog Funster
    Jul 13, 2008
    1,129
    521
  6. Boringfrog
    Boringfrog Funster
    Jul 13, 2008
    1,129
    521
    • Thanks Thanks x 1
  7. Jaws
    Sep 26, 2008
    18,593
    22,679
    Narrfoook
    A very useful site B F, but again no figures given for the standard 60w fluorescent .. Just about everything else mind you LOL !!
    • Like Like x 1
  8. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,066
    2,915
    Kendal, Cumbria
    The info is under each tube in Oileys link. Possibly a bit approximate though.
  9. Borderland
    Borderland Funster
    Nov 5, 2014
    433
    2,473
    Borders
    In the link given by Olley is says that the 5ft led tube is equivalent to a 58W fluorescent. Is this the information you are after.
    • Thanks Thanks x 1
  10. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,113
    3,517
    walthamstow east london
    probably no help at all but i replaced the 2x300m mm flourescents in the van with four strips stick on of led the same length and the leds are brighter
    • Thanks Thanks x 1
  11. Jaws
    Sep 26, 2008
    18,593
    22,679
    Narrfoook
    Not exactly but I think it is about as close as I am gonna get to be honest ! :)
    I will have to take a stab at the colour temperature of a standard tube..
  12. Jaws
    Sep 26, 2008
    18,593
    22,679
    Narrfoook
    Think I may have found it !! 3500k seems to be the standard..
    Now I have all the info needed :)
    Thanks to everyone for the input.. greatly appreciated :)
  13. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,891
    17,549
    YO11 2BD
    There is no direct wattage comparison for LED/fluorescent.
    A regular 60w filament bulbs LED equivalent could be 4w, 5w, 6.5w...DEPENDING on chip type and quality of manufacture.
    • Like Like x 2
  14. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,509
    9,935
    we just had a load of fittings changed at our church. the sparky said that the old ones were about 3500k equivalent but recommended 4500k, with an option of even brighter. pleased we chose the 4500k as they really improved the overall light level
    • Like Like x 1
  15. bubble63
    bubble63 Funster
    Aug 10, 2012
    547
    498
    cambridge
    Just a point of order john
    Why do you want to match the fluorescent colour, why not pick a temperature that suits the room use best
    I find fluorescence colours a bit harsh
    • Like Like x 1
  16. Jaws
    Sep 26, 2008
    18,593
    22,679
    Narrfoook
    I have decided to go LED as at least one ( if not all ) of the units in the kitchen is on from the moment we get up until late in the evening
    Woman is always whinging about any change to lighting so it is important I get as close to 'normal strip light ambiance as possible
    • Like Like x 1
  17. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    9,804
    11,281
    E Yorks
    I always thought fluorescent lamps were efficient power-wise anyway, are LEDs that much better?
  18. Robin McHood
    Robin McHood Funster
    Mar 10, 2016
    249
    204
    Scottish Borders
    @Jaws you may already know this but the larger the Kelvin number the 'cooler' or the closer to daylight the light, the lower the number the closer to a filament lamp it gets. We tend to use Colour 840 or Phillips 840 en masse on board. They have a colour of 4000K which is a "coolish warm" light in Phillips paralance and seems to strike a decent balance between colour rendition and harshness
    The old standard for fluoros was a colour 35 which was at 3500K and referred to as white though most people associate that with 'them orrible fluorescents'
    Its only recently LEDs were able to get to the lower warm Kelvin numbers usually by mixing in yellow or red led chips. I've got 2700k ones in the house and moho & SWMBO tolerates those as being close to the old filament lamp colour.
    • Informative Informative x 1
  19. Robin McHood
    Mar 10, 2016
    249
    204
    Scottish Borders
    In a word Yes. Fluoros arent bad compared to filament lamps or halogens but LEDs are 10 times more efficient generally speaking and have a much longer life. They do have problems , our kitchen has T-H fittings and Leds just dont work as the fitting is designed to use the backscatter light from the backside of the TH spots and LEDs dont have any. They also produce a much sharper cut-off so the shadows can be in high contrast to illuminated areas..
  20. Robin McHood
    Mar 10, 2016
    249
    204
    Scottish Borders
    • Thanks Thanks x 1
