Not Another Reverse Polarity Question, well .... (1 Viewer)
Bailey58
8,801
29,464
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
Thought I'd plug the Kipor into the motorhome for the first time (ok ok, if it's good enough for JJ and Roadrunner .......) and the onboard display is warning me of reverse polarity. :Sad:
I'm using my usual EHU cable which is fine at home, and on site, so I googled it like you do and it's opened up all the usual can of worms with Kipor's floating earths mentioned among many other things.
With toast and coffee at hand I will await Funsters knowledgeable band to put me at ease - or not. :Smile:
John & Joan
1,425
774
Darlington
10 years this time
With toast and coffee at hand I will await Funsters knowledgable band to put me at ease - or not. :Smile:
All generators are floating earth. AC is alternating current 50 times a second between +ve and -ve. Your onboard display may not like it but it should do no harm. Just dont touch the teminals and you will be OK.
I ran generators for 10 years on a storage site (warden) 24/7 and came to no harm other than being covered in oil when I checked the oil once and didn't put the filler cap back on properly. The generator was inside a shed and the oil hit the roof when I restarted it and showered me in hot oil. Standing outside of the caravan naked in sub zero temperatures trying to scrub oil off yourself is no fun.
JJ
Mágica
May 1, 2008
19,258
48,025
Burstner Privilege T
over 50 years
Sorry I can't be of much help... you probably wouldn't want to do what I would do (stick a sticker over the reverse polarity warning sign... out of sight out of mind)...:Eeek:
I really only replied to show you my new avatar...:ROFLMAO:
JJ :Cool:
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
All generators including Kipors I believe have an earth terminal, if you were toconnect that to an earth spike the warning will disappear. most don't both and come to no harm.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
You are going to die:Eeek:
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
your not supposed to start the genny in reverse :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
haganap
12,757
26,436
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
Maybe after yesterdays result Rolf, you might want to not worry about it and hope it knocks you out only to wake up when it the noisy neighbours quieten down a bit :winky:
Bailey58
Bailey58
8,801
29,464
Norfolk and Toftir.
Sold
I really only replie to show you my new avatar...:ROFLMAO:
JJ :Cool:
At least I was there JJ, unsurpassed success over many years makes one a bit blase about these things. City deserved a 3-1 win, the rest was suicide attacking play from United. Think Fletcher's goal was the best of the game though. :Smile:
Oh, I was pushing the start cord, was I supposed to pull it? :Doh:
I just ignore the tv and the papers for a few days Paul, as JJ says, out of sight out of mind. :Smile:
wolly
20
ripon n yorkshire
van conversion
40 plus motorhoming and tugin
wolly north yorkshire
QUOTE=Rolfarris;491213]Thought I'd plug the Kipor into the motorhome for the first time (ok ok, if it's good enough for JJ and Roadrunner .......) and the onboard display is warning me of reverse polarity. :Sad:
With toast and coffee at hand I will await Funsters knowledgeable band to put me at ease - or not. :Smile:[/
take a wire from your plug and join nutral to earth and your reverse polarity light will go out.and it is safe to do so. i have done this with my honda hope it helps you.:thumb::thumb:
Bailey58
Bailey58
8,801
29,464
Norfolk and Toftir.
Sold
take a wire from your plug and join nutral to earth and your reverse polarity light will go out.and it is safe to do so. i have done this with my honda hope it helps you.:thumb::thumb:[/QUOTE]
Just to make sure I get this right, you mean open up the 13amp plug and join the neutral and earth pins with an extra wire?
chatter
3,689
937
cheshire
5th wheel
it is quite safe, just dont play with anything electriacal while plugged in, as roger said if you want it to go out get a piece of copper pipe drill hole in one end and attach a wire, hammer into ground the attach other end of wire to the earth point on your genny - light will go out
scotjimland
2,291
9,938
A Woosh bang
if you want it to go out get a piece of copper pipe drill hole in one end and attach a wire,[HI] hammer into ground [/HI]the attach other end of wire to the earth point on your genny -[HI] light will go out[/HI]
yeah.. because you've just spiked the underground mains cable ... :ROFLMAO:
